itr pistons in a gsr question?
Old Jun 6, 2007 | 07:25 PM
r.f.b's Avatar
Default itr pistons in a gsr question?
i am goinog to put in itr pistons and rings into my 96 gsr is there going to be a problem with the height of the itr's piston then my stock gsr's or any problem's that might accure at all....looked evrywhere for info but none just want to know if i will have any problems with the changover, thanks
Old Jun 6, 2007 | 07:27 PM
sauceja's Avatar
Default Re: itr pistons in a gsr question? (r.f.b)
Use P30 pistons/pins and oem rings.
http://www.hmotorsonline.com
has them, Itrs would be fine though. Might as well get ITR or CTR cams and a tune.
Old Jun 6, 2007 | 07:32 PM
r.f.b's Avatar
Default Re: itr pistons in a gsr question? (sauceja)
im putting them in for a buddy and just wanted to check out as much info i can before doing the changover, but the other stuff can come later, its a little easier. thanks
Old Jun 6, 2007 | 08:39 PM
nokturnal_munkeeboy's Avatar
i have jdm itr piston in my car , i have no problems
Old Jun 7, 2007 | 12:25 AM
Championship's Avatar
Default Re: itr pistons in a gsr question? (nokturnal_munkeeboy)
no no problems should you encounter for an OEM pistons.
PCT's in the other hand....no good, CR passes 12.8:1 and terrible for big cams and valvetrain, and a ported head.......
psst. i have them
jakku
18
Mar 27, 2012 06:09 PM
mac_24_seven
11
Aug 7, 2007 02:31 PM
OBD1 Kenobi
Dec 15, 2002 11:43 PM
JD_B18CDX
Jul 3, 2002 07:51 AM
