swaping lugs from an odyssey. Gotta questions.
Old Jun 6, 2007 | 07:01 PM
ipihuc's Avatar
Default swaping lugs from an odyssey. Gotta question.
I have an odyssey that i am about to sell. Before I do I want to swap the 5 lugs for my accord. Was wondering if it was safe to swap my accord's lug onto the van. Is there any kind of safety issues if I did this?
Old Jun 6, 2007 | 08:26 PM
JDM_Acccord's Avatar
Default Re: swaping lugs from an odyssey. Gotta question. (ipihuc)
make sure it's the same thread size. other than that, it should be fine.
Old Jun 7, 2007 | 03:19 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: swaping lugs from an odyssey. Gotta question. (JDM_Acccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Acccord &raquo;</TD></TR><TR><TD CLASS="quote">make sure it's the same thread size. other than that, it should be fine.</TD></TR></TABLE>
I think you missed the point of what they are asking. I believe they are saying they want to do a 5 lug swap of Odyssey parts onto their Accord and then take the 4 lug setup and put it on the Odyssey. Unless I'm wrong and all they want to do is swap the wheel studs but that doesn't make sense to me.
ipihuc,
No issues I can think of other than make sure the tire OD going back onto the Odyssey matches what was on there before so the speedometer isn't off. I would also make sure you note what you have changed on the Odyssey when you go to sell it so the new owner knows they have to buy front brake parts for an Accord and not an Odyssey.
Edit:
Are the brakes of the Odyssey bigger than the Accord? If so, that could be a draw back because you wouldn't want to risk "downgrading" the braking of a heavier vehicle. Wouldn't want to have something happen and have it come back to bite you in the ***.
Old Jun 7, 2007 | 06:50 AM
Bird333's Avatar
Default Re: swaping lugs from an odyssey. Gotta question. (TouringAccord)
I think the rotors are thicker (25mm vs. 23). I don't know if the calipers are bigger other than them having the 25T brackets.
Old Jun 7, 2007 | 07:48 AM
ipihuc's Avatar
Hey thanks for the input, I'll let you know once i finish.
drktorn
Jan 24, 2013 08:15 PM
JDMguy88
Apr 2, 2008 09:18 PM
philosofy1
Jan 6, 2005 04:14 PM
RUBZERK
Feb 5, 2004 05:29 AM
