TORQUE SPECS steering wheel nut
Old Jun 6, 2007 | 06:52 PM
previerguy's Avatar
Default TORQUE SPECS steering wheel nut
what is the torque specs for the 19mm nut that holds the steering wheel to the steering column?
ialready tried doing a search-
Old Jun 6, 2007 | 07:41 PM
previerguy's Avatar
Default Re: TORQUE SPECS steering wheel nut (previerguy)
thnaks anyways guys... according to chilton's 134 FOOT lbs.
surprising, im just gonna tightn as much as i can by hand.. im not that tic
Old Jun 6, 2007 | 08:34 PM
ED9man's Avatar
Make sure you really tighten that thing down, mine started to come loose and I tightened it pretty good the first time, you really have to crank it.
Old Jun 6, 2007 | 08:49 PM
Richard...'s Avatar
Default Re: (ED9man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ED9man &raquo;</TD></TR><TR><TD CLASS="quote">Make sure you really tighten that thing down, mine started to come loose and I tightened it pretty good the first time, you really have to crank it.</TD></TR></TABLE>
just pull out the impact gun and give it a blast should be good too go!
Old Jun 7, 2007 | 11:08 AM
ndogg's Avatar
i was pretty sure it was 50lbs
Old Jun 13, 2007 | 06:13 PM
previerguy's Avatar
pretty sure? THEN DONT POST!
Old Jun 14, 2007 | 07:13 AM
ndogg's Avatar
Default Re: (previerguy)
i'm trying to help you out man. i know for a fact it is not 134 lb/ft. no need to be a *****.
Modified by ndogg at 10:01 AM 6/14/2007
Old Jun 14, 2007 | 04:48 PM
Richard...'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by previerguy &raquo;</TD></TR><TR><TD CLASS="quote">pretty sure? THEN DONT POST!</TD></TR></TABLE>
<FONT SIZE="12">WTF</FONT>
talk about been an *******
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ndogg &raquo;</TD></TR><TR><TD CLASS="quote">i'm trying to help you out man. i know for a fact it is not 134 lb/ft. no need to be a *****.
Modified by ndogg at 10:01 AM 6/14/2007</TD></TR></TABLE>
Agreed to people have told you an answer i said just get the impact gun out and he gave you a tq spec!
Old Jun 22, 2007 | 09:03 AM
previerguy's Avatar
Default Re: (richard7968)
B E I N G a *****, and iguess iam one on honda-tech. seriously.. "ithink it was 50lbs" sure, ill install it at that spec and then have the nut come loose on me while im driving, iwont die but itd be a pain in the *** to have to take everything apart again. if youre gonna flame me at least slap me with a honda manual telling me im wrong-
mods, lock this thread or ban me
honda-tech will be forever populated by "******"
Old Jun 22, 2007 | 09:10 AM
previerguy's Avatar
^ I LISTED THE TORQ SPEC. FROM chiltons in the second post, at least read "*******." unless you wanted to quote a honda shop manual.. remember to use MLA format-
Old Jun 24, 2007 | 08:47 AM
ndogg's Avatar
you are one of the biggest ******* morons i have seen here on HT. i was going from memory and came up with 50... you actually read the manual (which clearly states 36 lb-ft) and you somehow got 134lb feet from that?
go end yourself.
Old Jun 24, 2007 | 12:03 PM
Richard...'s Avatar
Default Re: (ndogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ndogg &raquo;</TD></TR><TR><TD CLASS="quote">you are one of the biggest ******* morons i have seen here on HT. i was going from memory and came up with 50... you actually read the manual (which clearly states 36 lb-ft) and you somehow got 134lb feet from that?
go end yourself.</TD></TR></TABLE>
LOL
BubLBack
Mar 20, 2007 08:09 AM
mrdeadman
Jul 27, 2005 08:52 AM
vtec_crazy
Apr 16, 2005 09:14 AM
5thGenCivicKid
Mar 14, 2005 02:44 PM
Xymox007
Oct 17, 2004 07:07 AM
