Newbie to honda and fwd
Old Jun 6, 2007 | 06:36 PM
dyalnowalker's Avatar
Default Newbie to honda and fwd
Hey all,this is my first post and my first honda. I picked up my '99 prelude from my local honda dealer, and now have some questions. It has lost all insignia stating the car type and maker. How am I suposed to tell what type I have (base or sh). From what I have found so far, the chassis code is bb6. Does this differ between the two modles? I have also noticed that its difficult to shift into 1st. The car has 109,000 and no other issues as of yet. Any info that you all have would be greatly appreciated.
ps: is there anything that I should be looking forwad to as far as little issues popping up due to the milage? Thanks once again.
Old Jun 6, 2007 | 06:41 PM
mafia's Avatar
Default Re: Newbie to honda and fwd (dyalnowalker)
give me 1st 10 letters of ur vin and ill tell you what u have.
Old Jun 6, 2007 | 07:05 PM
Default Re: Newbie to honda and fwd (mafia)
right
VIN:JHMBB614XXCOO8850
Old Jun 6, 2007 | 07:14 PM
mafia's Avatar
its a 5 speed BASE modle
Old Jun 6, 2007 | 07:16 PM
mafia's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dyalnowalker &raquo;</TD></TR><TR><TD CLASS="quote">right
VIN:JHMBB614XXCOO8850</TD></TR></TABLE>
1 = stick if in that spot there is a 2 in means its a auto.
4 = BASE if its a 5 its a type-SH
Old Jun 6, 2007 | 07:17 PM
Thank you much sir
Old Jun 6, 2007 | 07:19 PM
mafia's Avatar
yup, anything els?
Old Jun 6, 2007 | 08:13 PM
just trying to take out the understeer. im so used to my little rwd roadster.
Old Jun 6, 2007 | 09:11 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dyalnowalker &raquo;</TD></TR><TR><TD CLASS="quote"> I have also noticed that its difficult to shift into 1st. </TD></TR></TABLE>
As far as that issue, the tranny won't go into 1st unless you are going under 5-10 mph...sometimes even less it seems like.
Old Jun 7, 2007 | 04:22 PM
JT's Avatar
JT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dyalnowalker &raquo;</TD></TR><TR><TD CLASS="quote">just trying to take out the understeer. im so used to my little rwd roadster.</TD></TR></TABLE>
You could try installing a larger dia rear swaybar like the 27mm from Progress. It will greatly reduce or eliminates the understeer depending on the settings.
Old Jun 7, 2007 | 04:56 PM
cb7tougeracer's Avatar
Default Re: Newbie to honda and fwd (JT)
thats a nice first honda mine was a 93 civic welcome though
Old Jun 8, 2007 | 02:30 PM
Default Re: Newbie to honda and fwd (cb7tougeracer)
thank you all so much. as to that sway, does anyone have much in the way of exprnc. using it. im realy picky about the parts i use on my cars. and for that tranny issue, it occurs at a dead stop. i ususally try not to shift down into first while rolling
Old Jun 8, 2007 | 02:41 PM
I-4's Avatar
I-4
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dyalnowalker &raquo;</TD></TR><TR><TD CLASS="quote">thank you all so much. as to that sway, does anyone have much in the way of exprnc. using it. im realy picky about the parts i use on my cars. and for that tranny issue, it occurs at a dead stop. i ususally try not to shift down into first while rolling</TD></TR></TABLE>
Smart
I have a '00 Base model, it tends to do that also, just pull it back into 2nd and then into first again, It hardly happens ever but I got used to it.
pinoyk20
Jan 1, 2007 08:18 PM
tommy.
Jul 23, 2006 03:33 PM
EJay1
25
Oct 4, 2005 08:04 PM
Tad
May 26, 2004 06:25 PM
Yellow Dragon
May 9, 2003 02:54 PM
