Help with wiring up two fuel pumps for my surge tank setup.
Old Jun 6, 2007 | 05:13 PM
BB6-213's Avatar
Default Help with wiring up two fuel pumps for my surge tank setup.
I am in the last stages of getting my car ready to start and I need to wire up the fuel pumps. If you don't know, I am using a surge tank, which will be the walbro 255hp intank feeding the surge tank that will feed the aeromotive a1000. I currenty have the walbro using the stock wiring going with a relay so I wouldn't have voltage drop. Now to wire up the a1000, can I pretty much just use the same setup as the walbro and just "Y" it off of the harness and go to the pump, also with a relay. So to simplify what I said, pretty much just think of it as having 2 sets of connectors instead of one for the fuel pump, one going to the tank, one to the external. Hope that makes sense.
Old Jun 6, 2007 | 05:56 PM
tony413's Avatar
im not a wiring type of person but use the stock wiring to power the walbro and then use a power wire, relay, and ground to power the Aero or if you want to be able to turn the walbro on/off add a 20A rocker switch
Old Jun 7, 2007 | 02:40 PM
BB6-213's Avatar
thanks, anyone else.
Old Jun 9, 2007 | 06:47 AM
BB6-213's Avatar
que?
jdm_h22
Oct 19, 2012 02:30 PM
Bond
Oct 5, 2009 05:37 PM
RACEPAK
Feb 10, 2008 10:58 AM
Pandahatch
Dec 23, 2005 11:32 PM
