1998 Honda Accord Ex Automatic Transmission Shifts Rough
Old Jun 6, 2007 | 03:24 PM
bngguy's Avatar
Default 1998 Honda Accord Ex Automatic Transmission Shifts Rough
Hi,
I have a 1998 Honda Accord Ex, the transmission has been shifting rough lately when it shifts from 1st to 2nd , but the remaining shifts are smooth, before i do a transmission flush i would like to know if the problem is due to bad timing, any pointers in the right direction would be greatly appreciated.
Thanks
Tim
Old Jun 6, 2007 | 04:01 PM
hondadude's Avatar
Default Re: 1998 Honda Accord Ex Automatic Transmission Shifts Rough (bngguy)
Don't shoot the messenger...however;
that trans was crap the day it rolled off the assembly line.
overwith....
history...
kiss it goodbye.....
Old Jun 7, 2007 | 03:06 AM
streetxdreamer's Avatar
Default Re: 1998 Honda Accord Ex Automatic Transmission Shifts Rough (Evil Monkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude &raquo;</TD></TR><TR><TD CLASS="quote">Don't shoot the messenger...however;
overwith....
history...
kiss it goodbye.....</TD></TR></TABLE>
thats assuming he has a v6 right?
Old Jun 7, 2007 | 07:43 AM
professorman's Avatar
Default Re: 1998 Honda Accord Ex Automatic Transmission Shifts Rough (streetxdreamer)
yes, the V6 auto transmission is crap. Lets hope you have less than 100k miles. I think Honda extended the warranty on them. I dont remember how many years, is it 10 years or 7?
Old Jun 7, 2007 | 07:45 AM
YeuEmMaiMai's Avatar
98 cars are not covered under any warranty........neither are the 99 and 02 models.
the 00 and 01 models are 7 yr 9 mo or 109K miles
trans is a POS and you need to REPLACE IT.
Old Jun 7, 2007 | 11:53 AM
bngguy's Avatar
Default Re: 1998 Honda Accord Ex Automatic Transmission Shifts Rough (profroopchan)
No its not a V6
Old Jun 7, 2007 | 01:02 PM
doesn't matter all accords with the above listed model years are covered
Old Jun 7, 2007 | 04:13 PM
JDM_DC4_Fanatic's Avatar
Default Re: 1998 Honda Accord Ex Automatic Transmission Shifts Rough (YeuEmMaiMai)
So, whats the deal with the tranny's? I've never riped one apart before. Does the pump burn out? or a clutch pack or what? I know that on all new chryslers, you need to run a particle filter inline with the cooler return line and a sight glass in the pressure line because they plug up and burn out the pump.
I'm just curious because people just say its crap, but nobody seems to have a solutuon to the problem. Its just an automatic "go to the dealer" thing...I dont think thats very productive for a technical forum. In addition to that, there must be a way to prevent this from happening if someone owns a low milage vehicle. It cant 'just be that way'. There has to be a reason, and a solution.
Old Jun 7, 2007 | 04:54 PM
jravensc's Avatar
Default Re: 1998 Honda Accord Ex Automatic Transmission Shifts Rough (JDM_DC4_Fanatic)
Bump for JDM layin it out on the table. Wish I knew.
Also because I have a 99 EX auto, and didn't realize these trannys had so much trouble. But I guess it would have probably cost as much to teach my girlfriend to drive a manual.
Old Jun 8, 2007 | 07:11 AM
main problems are
differental bearings are crap and disintigrate easily causing reduced fluid flow and leaking axle seals
2nd gear clutch pack is already low on lube but the above problem causes the clutch pack to wear out and slip
mvi51
Transmission & Drivetrain
Jan 25, 2018 11:37 AM
pstevens90
Nov 16, 2014 04:32 PM
turbolsvtecej1
Aug 4, 2012 03:10 PM
ryanjg11
Oct 31, 2009 12:01 AM
