Reverse Lights
Old Jun 6, 2007 | 12:56 PM
everythingwentblack's Avatar
Default Reverse Lights
My auto to manual converted EG doesnt have reverse lights and I cant find any info on how to wire them. I need some help so i can pass inspection! I cant find anything anywhere, maybe its just because im a derelict.
Old Jun 6, 2007 | 07:05 PM
tmanrose2007's Avatar
Default Re: Reverse Lights (everythingwentblack)
Don't worry I have the same problem. My back up lights don't work either. Just hook them up to a switch but the switch has to light up indicating your back up lights are on.
Old Jun 7, 2007 | 07:13 AM
chicows18's Avatar
On the shifter for the auto transmission, you will see a 14-wire plug. Cut the plug from the auto shifter assembly, and leave about 5 inches of wire. Looking at the plug, the positions are (left to right) (top row) 14,13,12,11,10,9,8 and (bottom row) 7,6,5,4,3,2,1.
Starter (top) Sensor:
There are two heavy gauge wires (position #11 and position #12). Connect these two wires to the top sensor (clutch interlock switch) on the clutch pedal assembly. This will only allow the car to start when the clutch pedal is engaged. In other words, every time you press the clutch you will close the circuit.
Cruise Control (bottom) Sensor:
The bottom switch is your cruise control disable switch. Run two wires from the switch: connect one to the position #7 (black) and the other to #13 (pink). Every time you press the clutch pedal, the cruise control will disable.
Removing the Key:
On the 14-wire plug, there is a black wire you will need to connect to a green wire with a white stripe. This puts the car in "park" so you can take the key out at any time.
Reverse Lights:
Look at the plug you used on the engine wiring harness to hook up to your reverse sensor on the manual transmission. Run two wires from this switch to the yellow wire and a green wire with black stripe (positions 4 and 5) at the big plug that you cut off from the auto shifter. Now your reverse lights should work.
Hope this helps.
MyWhiteEJ6
Jun 17, 2013 04:28 PM
bpatterson6003
Apr 14, 2009 10:00 PM
mikehawk
Jan 2, 2009 07:19 AM
Vinceg99
Nov 9, 2002 06:02 PM
Sloth
Nov 27, 2001 11:13 PM
