Purge selenoid removal
Okay I plan on removing my charcoal canister and mounting my catch can in it's spot. When I do this I know I have to plug all of the vacuum lines except the gas vent. My question is if I unplug the purge selenoid at the harness will it throw a CEL? I am obd1 so my MAP is on the TB, so I was wanting to get rid of those 2 things from the firewall as well.
Mine does not throw a code. its obd0 if you cap off the vent line from the tank it will build pressure eventually enough to rise the fuel pressure, generally messing with things.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChickenH »</TD></TR><TR><TD CLASS="quote">Mine does not throw a code. its obd0 if you cap off the vent line from the tank it will build pressure eventually enough to rise the fuel pressure, generally messing with things.</TD></TR></TABLE>
Like I said cap of everything EXCEPT the tank vent!
Anyone else more sure about the purge selenoid plug?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec91hatch »</TD></TR><TR><TD CLASS="quote">
Anyone else more sure about the purge selenoid plug?</TD></TR></TABLE>
I did the same I put a moroso can right where the charcoal canister was. I unplugged the sol. and no CEL. I just put a 1/4" hose on the tank vent tube on the firewall and ran it down pointed to the ground.
Anyone else more sure about the purge selenoid plug?</TD></TR></TABLE>I did the same I put a moroso can right where the charcoal canister was. I unplugged the sol. and no CEL. I just put a 1/4" hose on the tank vent tube on the firewall and ran it down pointed to the ground.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy »</TD></TR><TR><TD CLASS="quote">
I did the same I put a moroso can right where the charcoal canister was. I unplugged the sol. and no CEL. I just put a 1/4" hose on the tank vent tube on the firewall and ran it down pointed to the ground.</TD></TR></TABLE>
I never thought to look if there was a code for the purge selenoid.
That is what I plan on dooing as well. I will be making my can though. I've got a pretty good idea for one so check out my build for it soon. Thanks guys.
bbarbulo
Honda Civic (2001 - 2005)
Jul 2, 2013 05:09 PM
