P0452 Engine Code help ASAP
Old Dec 24, 2009 | 08:49 PM
runtohell121's Avatar
Default P0452 Engine Code help ASAP
Ok, I own the 1998 Acura Integra LS automatic non-vtec. Lately, an engine code popped up and my OBD-II scanner picked it up as a P0452 code. I did search, saying gas cap tightening, but I've done that everytime I fuel up and still have the same code. Any other things I need to look at for this code?
Old Dec 24, 2009 | 10:23 PM
Default Re: P0452 Engine Code help ASAP
BUMP
Old Dec 25, 2009 | 07:04 AM
BUMP
Old Dec 25, 2009 | 03:36 PM
anyone
Old Dec 25, 2009 | 05:47 PM
Pimpsherm2009's Avatar
try to get a new gas cap sometimes the gasket goes bad...
Old Dec 25, 2009 | 06:06 PM
I bought the gas cap not long ago though?
Old Dec 26, 2009 | 05:24 PM
does the code reset and clear? if not read this The Fuel Tank Pressure sensor changes resistance based on the fuel tank pressure (or vacuum). A vacuum is considered negative pressure.
The PCM provides a 5.0 volt reference and a ground. The Fuel Tank Pressure sensor signal varies between ground and 5.0 volts as fuel tank pressure varies. The Fuel Tank Pressure sensor voltage increases as the fuel tank pressure decreases (negative pressure, or vacuum). The Fuel Tank Pressure sensor voltage decreases (positive pressure, low voltage) as the fuel tank pressure increases. The PCM uses the Fuel Tank Pressure sensor voltage for EVAP system leak detection. This DTC sets when the Fuel Tank Pressure sensor signal goes below a predetermined value.
where do u live are you up north also?? check connections for corrosion...
Old Dec 26, 2009 | 05:54 PM
I live in the Northern/Central part of California. So far I resetted the code, waiting to see how long will it pop up again.
Old Dec 26, 2009 | 05:57 PM
so Im guessing u never see snow?
Old Dec 26, 2009 | 07:03 PM
nope, only rain.
Old Dec 26, 2009 | 07:04 PM
ok then check that sensor and all connections
Old Dec 26, 2009 | 07:49 PM
where would the sensor be located at?
Old Dec 27, 2009 | 10:06 AM
it would be under the drivers side near the fuel tank, this is prolly whats causing the light to come on I found this on http://www.acuraoemparts.com/delray/...All&vinsrch=no
04101-P72-A00 SENSOR ASSY., VENT PRESSURE 128.00
while ur under there i would replace this too 17371-S02-L01 VALVE (TWO-WAY) 41.70
this should fix the problem....
Old Dec 27, 2009 | 03:16 PM
mmkay, thanks, I'll look into it and see what's the cheapest way I can replace things.
Old Dec 28, 2009 | 09:56 PM
Ok, I took the easy way out, replacing the fuel cap, engine light came back on.. so replacing the Sensor ASSY., Vent Pressure and Valve Two Way will fix my problem for sure?
Old Dec 29, 2009 | 04:59 AM
it will just make sure u get the check eng light reset, there are a few other things to check like for vac leaks and other emissions parts like VALVE, CANISTER VENT SHUT and VALVE (THREE-WAY)..these are located in the engine bay on the passenger side near the battery almost directly under the battery. numbers 11 and 12 in the drawing...
Old Dec 29, 2009 | 08:23 AM
wouldn't that be P1457 code area? I had this code before, took it to a mechanic, they fixed that code, but the P0452 came on after that..
Old Dec 29, 2009 | 12:06 PM
I wasnt sure if you looked at all those sensors as well...
Old Dec 29, 2009 | 07:46 PM
Heh.. I'm not sure also, the mechanic i took it to said it was clogged, so he pumped air through it which deleted the P1457 code (evap part)..
Old Dec 29, 2009 | 08:25 PM
Spawne32's Avatar
http://www.obd-codes.com/
bbarbulo
Honda Civic (2001 - 2005)
Jul 2, 2013 05:09 PM
mugenboi
May 24, 2007 11:49 AM
full Circling
Aug 1, 2006 03:09 PM
esoterEK..
Jun 11, 2004 07:06 AM
