wetsand with what grit before laying clear coat
Old Jun 6, 2007 | 11:52 AM
msinsky14's Avatar
Default wetsand with what grit before laying clear coat
after two medium coats of base, what grit paper do I use to sand the base before I lay a think tack coat of clear?
thanks
ps-my first paint job, so any imput will be appreciated
Old Jun 6, 2007 | 12:05 PM
WihaSi's Avatar
Default Re: wetsand with what grit before laying clear coat (msinsky14)
Don't really need to sand the base. If you want you can lightly sand the dirt nibs with 2000 grit (dry, just scuff lightly), but other than that just tack rag it, and shoot it with clear. And I would go 3 coats of base, just to make sure you have obtained coverage.
Old Jun 6, 2007 | 03:41 PM
msinsky14's Avatar
Default Re: wetsand with what grit before laying clear coat (WihaSi)
sounds like a plan
Old Jun 6, 2007 | 06:13 PM
nikolai.'s Avatar
even if you sand out the nibs with 2000, id still spray some clear over those spots.
Old Jun 7, 2007 | 03:24 AM
powerflow's Avatar
Default Re: (nikolai.)
Not all paint covers the same, so make sure your getting complete coverage. De-nib the base before your last coat of base, so spray another coat of base before you clear. If your spraying a solid color, you should be good, but a heavy metalic, you should be extra meticulous and observant before you clear. If you don't need to nib / fix anything on the base then threre is no reason to sand, just clear it.
drumminforev
16
Feb 19, 2023 09:18 PM
akces
Paint and Body
Apr 4, 2008 04:45 PM
drumminforev
Dec 8, 2006 10:10 AM
dxhatch93
Sep 24, 2005 11:51 PM
