Grinding Calipers - What to use /w air tools?
Old Jun 6, 2007 | 11:02 AM
JDMflavor_EJ's Avatar
Default Grinding Calipers - What to use /w air tools?
AEM BBK with 16 inch rims that are just a hair too small. The rims do fit, but when I rotate the rims with my hand there's a little resistance and I ended up slighly scratching the inner part of my rims.. doh.
So I'll need to grind/shave the end of the caliper.
My buddie has air tools and a nice compressor, but I don't know which adapter works best (I don't want something too weak or even too strong for my situation, any suggestions?
Modified by JDMflavor_EJ at 2:28 PM 6/6/2007
Old Jun 6, 2007 | 11:06 AM
Bull_head360's Avatar
dont go crazy, i just used a file to grind my calipers down for the fast brakes setup...i dont really see a need for air tools in this situation
Old Jun 6, 2007 | 11:30 AM
Default Re: (Bull_head360)
Neither do I, thanks for the filing suggestion... I will def. look into that; sounds great.
I asked about using air tool adapters because I think when people grind calipers or thick metals in general they use a grinding machine (which produces a lot of rotation/power) and thought there must be a similar adapter for those with air compressers.
Old Jun 6, 2007 | 11:48 AM
pdiggitydogg's Avatar
get wheel spacers instead
if possible, try 3mm or even 1/16" if its that small of an issue
Old Jun 6, 2007 | 12:03 PM
Default Re: (JDMflavor_EJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMflavor_EJ &raquo;</TD></TR><TR><TD CLASS="quote">Neither do I, thanks for the filing suggestion... I will def. look into that; sounds great.
I think what you're talking about is like an oversized dremmel with a 3" wheel(?) I have 1 of those but it's seriously overkill IMO. Glad I could help. The wheel spacer idea may work too, plus you wouldn't damage the finish on the caliper...
Old Jun 7, 2007 | 04:14 PM
One last bump - grinding will be Saturday.
Old Jun 7, 2007 | 04:21 PM
Libertariat's Avatar
Ek Forever y0!
Wheel spacers, makita, or a hand file.
/thread
Old Jun 7, 2007 | 04:52 PM
I dont at all understand why you would wreck your calipers when thin spacers would do the job
Old Jun 7, 2007 | 04:54 PM
A.E Motoring's Avatar
Default Re: (pdiggitydogg)
just run a thin spacer, problem solved
Old Jun 7, 2007 | 07:26 PM
Lou_EM1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">I dont at all understand why you would wreck your calipers when thin spacers would do the job</TD></TR></TABLE>
rofl "wreck" - you don't know what you're talking about
Just as someone at Sears, theyll have something Im sure
Old Jun 7, 2007 | 10:21 PM
huh...whatever you say...
but i think i know more than most
dont take "wreck" literally genius
Old Jun 8, 2007 | 02:51 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">huh...whatever you say...
dont take "wreck" literally genius</TD></TR></TABLE>
"you know more than most" - are we supposed to not take that literally either?
Old Jun 8, 2007 | 05:21 PM
Ek Forever y0!
No, because he does know more than most.
Old Jun 8, 2007 | 05:39 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMflavor_EJ &raquo;</TD></TR><TR><TD CLASS="quote">"you know more than most" - are we supposed to not take that literally either?
No, that is to be taken literally
I can see youre appreciative of the logical help I gave you...
andyz
Suspension & Brakes
Feb 14, 2011 06:47 PM
sykikchimp
12
Jun 9, 2010 04:03 AM
kommon_sense
Welding / Fabrication
Dec 16, 2009 08:10 AM
pbcdb
Mar 13, 2004 03:38 PM
43MA
Jan 16, 2003 05:02 PM
