Adding tach
Old Jun 6, 2007 | 09:53 AM
victor-dot-com's Avatar
Default Adding tach
It looks like I'll be buying a '96 Coupe without a factory tach. Is it possible to switch out the instrument cluster for one with a tach? Or should I just add an after market tach? I know that would be worlds easier, but if I get an aftermarket one, I want one that doesn't look out of place. In other words, I don't want a 5" diameter unit with neon backlighting perched on the stearing column. Any recommendations?
Thanks,
-Victor
Old Jun 6, 2007 | 10:14 AM
BlueIntegraBoy's Avatar
Default Re: Adding tach (victor-dot-com)
Yes, any gauge cluster from a 96-00 Civic that has a tachometer (LX, EX, Si, SiR, CTR) and even a 97-01 CRV will be plug and play into your Civic.
Old Jun 6, 2007 | 04:48 PM
vrrodri's Avatar
Will it also fit a EK hatch? Any wires to split?
Old Jun 6, 2007 | 04:50 PM
Default Re: (vrrodri)
Yes, it will fit and no, there aren't any wires you'll need to mess with.
Old Jun 6, 2007 | 05:05 PM
eg6sirll's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vrrodri &raquo;</TD></TR><TR><TD CLASS="quote">Will it also fit a EK hatch? Any wires to split?</TD></TR></TABLE>
i think theres several writeups in the faq section (search it)........
Old Jun 7, 2007 | 03:48 AM
Default Re: adding tach
Thanks for all the replies, I will check out the tech section now.
-V
hondanube2010
Jun 30, 2010 05:10 PM
B Hunter
Sep 15, 2005 08:32 PM
matchbox_EK
Aug 19, 2004 01:05 PM
kev tec96
Apr 9, 2003 04:55 PM
dxdriver
Jan 13, 2003 01:17 AM
