Spring rates? What is best?
Old Jun 6, 2007 | 06:30 AM
jgirard's Avatar
Default Spring rates? What is best?
I did a search in here for spring rates and coilovers but came up empty. Could you please enlighten me as to what you guys have on your Type R's (brand, spring rates) and what you use your car for (dd, track *****, both....)? I dd my R and I don't mind if it is too stiff because I don't really drive it that far to work, but I would like to know what you guys are doing out there.
Thanks,
Jon
Old Jun 6, 2007 | 07:04 AM
BABY NSX's Avatar
Default Re: Spring rates? What is best? (jgirard)
I'm currently running PIC Select coilovers with 12kF and 14kR and while being stiff I do find the ride very manageable during my short drive to work.
On the track these spring rates keep the car very flat and allow me to control the rear end of the car with little effort, and very predictable.
Old Jun 6, 2007 | 07:07 AM
George Knighton's Avatar
H-T Order of Merit
My car is basically track only. The only time it's on the road is coming and going to Summit Point.
The longest drive it will have been on recently is the upcoming VIR Expo.
Showa N1 Suspension. 14K Front / 16K Rear.
Some are sold as Showa, some are sold as Spoon, some are sold as Mugen...but they are all basically the same with the same valving. Occasionally you will find cheaper versions that are the same, but they are heavier because of heavier metal being used for the housings.
14K on the front to help with weight transfer when going into threshold braking.
16K on the rear to help rotate controllably.
Old Jun 6, 2007 | 07:09 AM
RTW DC2R's Avatar
Default Re: Spring rates? What is best? (BABY NSX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BABY NSX &raquo;</TD></TR><TR><TD CLASS="quote">I'm currently running PIC Select coilovers with 12kF and 14kR and while being stiff I do find the ride very manageable during my short drive to work.
Im running the same setup. Curious what damper settings you are using on the street? I run 4 in the front and 3 in the rear. its very stiff and can bounce some on slow rollers and dips, but it manages sharp bumps and rough roads very nicely. Cant wait to get them on the track at Expo.
Old Jun 6, 2007 | 07:17 AM
BABY NSX's Avatar
Default Re: Spring rates? What is best? (RTW DC2R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R &raquo;</TD></TR><TR><TD CLASS="quote">
Im running the same setup. Curious what damper settings you are using on the street? I run 4 in the front and 3 in the rear. its very stiff and can bounce some on slow rollers and dips, but it manages sharp bumps and rough roads very nicely. Cant wait to get them on the track at Expo. </TD></TR></TABLE>
I have been running with 2F and 1R. I don't want to make the rear too lively on the street. I haven't experimented too much yet (only put them in about 3 weeks ago), but so far I've been very impressed with the ride quality.
I'll be doing allot of experimenting with them at the Expo. I've only done one lapping day with them so far and haven't got them in the sweet spot yet. I tend to adjust things slowly so that I don't get any sudden surprises.
Old Jun 6, 2007 | 07:20 AM
WheaMyRyceGo's Avatar
im using PIC Apex 8/6k for daily driving, if you're not going to track your R or drive it real hard id probably go with 8/6k
Old Jun 6, 2007 | 07:33 AM
RTW DC2R's Avatar
Im gonna raise my car up slightly and try 1 click softer on front and rear. I have found so far (on the street anyway) that the softer you go on the 12/14 setup, you begin to feel like the springs are a little too stiff for the damper setting. The spring travels farther and very quickly on softer settings. But Im still experimenting also.
Modified by RTW DC2R at 1:21 PM 6/6/2007
Old Jun 6, 2007 | 08:31 AM
jgirard's Avatar
Guys, thanks for the responses so far.
Old Jun 6, 2007 | 12:41 PM
Dropspeed's Avatar
On my old ITR I ran 550 frt and 650 rear on a set of Apexi N1s. I didn't mind the ride at all even here in Michigan. With a rear Mugen bar the car felt very good on the track.
Matt
Old Jun 6, 2007 | 01:20 PM
JjuuN R's Avatar
Nice, Jim is bringing me the PIC Select R3 (12k/14k) set up as well to the Expo. Gald you and RTW are liking them.
Old Jun 6, 2007 | 01:31 PM
Mr.OB*GYN_Rhett's Avatar
Default Re: Spring rates? What is best? (JjuuN R)
im on ein Ra's, 12k/14k. I wanna sell for PIC's. Very streetable i think... sometimes i get sick of it. thats partly the reason i may be getting rid of them and that i dont even put them to use lol so overkill
Old Jun 6, 2007 | 03:09 PM
mugenracer's Avatar
I have Spoon N1's with 14kg front and 12kg rear. Front shocks are set on 3 and rears on 2 and i find it perfect for street driving. I have tried every combination of shock settings for hard front/soft rear and soft front/hard rear and found the current set up is best for me for street use.
Old Jun 6, 2007 | 04:12 PM
BABY NSX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JjuuN R &raquo;</TD></TR><TR><TD CLASS="quote">
Nice, Jim is bringing me the PIC Select R3 (12k/14k) set up as well to the Expo. Gald you and RTW are liking them. </TD></TR></TABLE>
I'll make sure you get a chance to experience them first hand
Old Jun 6, 2007 | 04:47 PM
an2ny888's Avatar
a bit ot.. do you guys know where i can find a spring adapter? i want to use the stock mounting hats with my mugen nz's, the problem is my swift springs are too small so the stock mounts can't hold them in place
dirtyharryhatch
Suspension & Brakes
12
Jun 23, 2010 01:34 PM
slowsol95
Mar 27, 2007 04:50 PM
Mr.EM1
Suspension & Brakes
Mar 4, 2005 10:09 AM
b18crx
Nov 14, 2003 06:12 PM
chri5
Sep 6, 2001 04:08 PM
