[4th Gen] Window problem.
Old Jun 6, 2007 | 04:04 AM
Pilky's Avatar
Default [4th Gen] Window problem.
So ya, im gonna try and save a few bucks and fix this myself. Yesterday before work i opened up door panel to take a peak around to see if i could get lucky and have an easy fix. Don't think thats gonna happen, anyways, the window neither goes up nor down, but i can hear the motor spinning. Is this enough info to steer me in the right direction on which part i need? Also, i couldnt really see a whole lot of the motor/regulator/winow, do i need to take that metal (panel??? or whatever you call it) off.
Old Jun 6, 2007 | 06:12 AM
nonvteclude's Avatar
Default Re: [4th Gen] Window problem. (Pilky)
try disconnecting the motor from the track then hitting the switch if the motor turns then it is probably the track. you will not be able to remove the metal without cutting it out, you should be able to get the motor out with the metal still there.
Old Jun 6, 2007 | 07:36 AM
preludefien
Guest
Posts: n/a
Default Re: [4th Gen] Window problem. (nonvteclude)
sounds like its not on the track.
Old Jun 6, 2007 | 03:25 PM
SnlpeR's Avatar
uh you dont need to cut metal
but you do have to remove the glass
and you gotta unscrew the side door molding by peeling off the rubber cover for that side molding
then you can unbolt the glass from the regulator
and then you can remove the glass
then...you can unbolt the regulator along with the motor and fish it out of the big hole in the bottom side of the door
ive done this about 5 times and i hate doing it
with my case...the teeth on the regulator just get flattened out by the gear teeth on the motor
so there will be a flat spot on the regulator where the gear teeth should be
the motor just spins on that section of missing teeth
try pushing the glass down with your hands while you press the down button to see if your glass moves down freely...and also back oup
Old Jun 7, 2007 | 03:45 AM
Pilky's Avatar
Default Re: (SnlpeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SnlpeR &raquo;</TD></TR><TR><TD CLASS="quote">try pushing the glass down with your hands while you press the down button to see if your glass moves down freely...and also back oup</TD></TR></TABLE>
Ok havent touched it since, but gonna take another look today. But the window now seems to fall down about 3 inches. I can also move the glass up and down while i press the botton also.
Old Jun 7, 2007 | 04:18 AM
SnlpeR's Avatar
does it go back up on its own on the lower part of the track?
Old Jun 7, 2007 | 04:24 AM
SnlpeR's Avatar
heres what TWO of my regulators looked like
what i did was cut a peice off a junked one and welded it onto the current one
so far so good
Old Jun 7, 2007 | 04:28 AM
SnlpeR's Avatar
btw i just remembered
i had another problem with the window too
the motor would spin but the window wouldnt move....
but the whole glass was able to move up and down with me pushing and pulling it
i took it apart to find out the "rubber bushng" inside the motor was broken
the stubs on that bushing that go into a couple of holes on a metal plate sliced off by old age
damn ive had so many problems with the window
i fixed it tho..but i forgot how
just replace the whole motor/regulator
Modified by SnlpeR at 1:38 PM 6/7/2007
Old Jun 7, 2007 | 04:36 AM
SnlpeR's Avatar
found some pics my gf took while my hands were greasy tryna fix this thing
see the stubs that broke off that go into those 2 holes?
so the motor spins but it doesnt turn the gear
i fixed it by screwing the metal plate onto the gear...i think
i seriosuly forgot
jca1972
Jun 14, 2007 09:44 AM
killaj12
Jul 11, 2006 07:04 PM
JamesQ
May 25, 2005 02:34 PM
spinez
Mar 20, 2005 11:03 AM
akimoto168
Jan 27, 2003 10:03 AM
