91 CIVIC OBD0 ECU PROBLEMS
Old Jun 6, 2007 | 01:56 AM
91A-SPEC-ED-HATCH's Avatar
Default 91 CIVIC OBD0 ECU PROBLEMS
THIS HAS BEEN DRIVING ME CRAZY SOMONE PLEZE HELP IDK WHAT THE PROB.IS I KEEP GETTIN A CHECK ENGINE ON MY STOCK 0BD 0 D-16 BLOCK 91 CIVIC THE ECU FLASHES ONCE I THOUGHT IT WAS A HEATED O2 PROB. SO I REPLACED IT BUT ITS STILL DOING IT SOMONE PLEZE FILL ME IN ON ANYTHING YOU THINK IT MIGHT BE THNX
Old Jun 6, 2007 | 02:08 AM
yz125rider21's Avatar
well take off the caps to start...and is code 1 the only code it throws???have you tried routing the wire from ecu to o2 sensor b itself on a seperate wire???
Old Jun 8, 2007 | 01:50 AM
Default Re: (yz125rider21)
yeah ive tried it all even as far as replacin the ecu as an alternetive and nothing? idk what else it could be.
Old Jun 8, 2007 | 03:54 AM
PURPLETERROR aka BIGMATT's Avatar
Default Re: 91 CIVIC OBD0 ECU PROBLEMS (91A-SPEC-ED-HATCH)
are you sure its code 1 and not code 10, is it a fast flash ofr a slow one?
Old Jun 9, 2007 | 01:09 PM
Default Re: 91 CIVIC OBD0 ECU PROBLEMS (PURPLETERROR aka BIGMATT)
yeah its a fast one and i thought it might be code ten but its not i even replaced the intake air temo. sensor.........
Old Jul 20, 2012 | 12:38 PM
Dazer 1991's Avatar
Im having same problems. Check engine light on. Throws a quick flash and nothing else. Cranks but aint going anywhere. Was thinking its a Ignition Coil since i changed dizzy cap, rotor, wires and spark plugs.
Old Jul 20, 2012 | 12:40 PM
Dazer 1991's Avatar
Also replaced O2 sensor and nothing
TheMightySi
K Series
16
Sep 22, 2013 02:06 AM
91GS-R in Vegas
Dec 20, 2007 04:55 PM
95_red_dc
Sep 11, 2006 06:32 AM
Charlie Moua
Jan 13, 2003 08:32 AM
