1995 ex problems...
Old Jun 5, 2007 | 11:41 PM
turpitude's Avatar
Default 1995 ex problems...
Hey guys, i have some questions & just need a bit of help.
1. My radiator water always decreases within usage of vehicle. it makes the engine rise in temperature and i have to keep refilling within time. (not good in hot humid weathers in Malaysia)
Wat could be the problem??
2. The engine seems to behave erratic stuttering when the air-con is turned on. wat could i do to fix on this??
3. From my observation, little white smokes coming from the exhaust pipe.. is it bcoz the need of change on my piston rings??
4. The engine oil seems to decrease very quick (needs to be refilled every once every 2weeks).
Why is this happening??
Any help would be much appreciated.
Thanks!
Modified by turpitude at 6:37 PM 5/15/2007
Old Jun 6, 2007 | 07:37 AM
02 accord's Avatar
Default Re: 1995 ex problems... (turpitude)
Blown head gasket.
Old Jun 8, 2007 | 11:09 PM
professorman's Avatar
Default Re: 1995 ex problems... (02 accord)
sound like your head gasket is definitely blown. Look in your radiator to see if oil is in it and look in your engine oil to see if coolant is in it. You can also get a compression test from a place like Autozone for free. The tester is only $20 so it is a good investment for future car purchases. If you test the engine and the compression is good, the car should be good.
It definitely sound like a blown head gasket though
zerobacan
Jan 28, 2021 04:16 PM
beat ignition
Honda Civic (2001 - 2005)
Jun 7, 2019 04:24 AM
Urboyrob
Jan 16, 2013 06:22 AM
turpitude
May 15, 2007 05:53 PM
ujhonda
May 11, 2006 04:29 PM
