Rebuilding my stock motor
Old Jun 5, 2007 | 11:34 PM
Hatchback93's Avatar
Default Rebuilding my stock motor
i have a 93 civic hatchback dx model and was planning on rebuilding or whatever you call it, or instead swapping. car has an auto transmission, and im planning on keeping it auto.
what are the best suggestions?
if rebuilding the d15b i think, what are things to replace or upgrade?
list all that's possible.
if swapping what motor has the best hp compatible with the civic and is worth it.
let meknow thanks!
Old Jun 5, 2007 | 11:40 PM
Team RS2's Avatar
Default Re: Rebuilding my stock motor (Hatchback93)
are you rebuilding or building?
there is no in between
anywyas rebuilds consit of, honing cylinders, myabe a micro polish new honda bearings i cannot stress you stay with oem honda bearings expletive acl nascar engines use honda bearings you're not making more power then them therefore shall be good "enough" for you.
rings, and a rebuild of the head, new seals, new seats,
Old Jun 5, 2007 | 11:54 PM
Default Re: building my stock motor (Team RS2)
will cam gears? rods and pistons? camshafts replacement help?
because ive read that building or whatever you call it might be cheaper than actually swapping another complete motor.
since my car is auto. is turboing it make anny difference?
if you can explain it to me, in every detail how to build my stock d15b that would be a great help thanks! again.
or an auto swap with any motor that will help?
Old Jun 5, 2007 | 11:59 PM
beverlykarl's Avatar
if your opting for more horsepower then its time to replace your engine with a b16b. but if you want less headache but retain the same HP then you would have to overhaul that engine then add some aftermarket parts to gain some horses.
Old Jun 6, 2007 | 12:00 AM
Default Re: (beverlykarl)
what aftermarket parts to add on, sorry im noob lol
Old Jun 6, 2007 | 12:03 AM
Team RS2's Avatar
Default Re: (Hatchback93)
you want to pay me? lol becuase otherwise im not going to tell you every detail, ok so you want it turbo?
then get going, id remove all the sharp edges in the rotating assembly no matter what,
open up some oil chamfers
a gasket match, maybe a cam set for turbo set ups, youd ned to go eagle rods, and some type of low comp piston
seruoisl man you're asking
ok i bought some paint, and a canvas how do i make a masterpieace?
Boostage
Oct 5, 2009 07:21 PM
adictionbass
Mar 17, 2005 08:19 PM
Burke
Feb 29, 2004 10:24 AM
9seccivicsi
Jan 19, 2004 05:30 PM
2muchPSI
Dec 15, 2002 06:09 PM
