Rubber washer required when installing Skunk2 shifter?
Old Jun 5, 2007 | 11:17 PM
yaoming315's Avatar
Default Rubber washer required when installing Skunk2 shifter?
i was looking at this write
http://www.clubcivic.com/board...06789
I think many do not include the rubber washer. Is it important, and should i purchase it from honda, or just use regular washers. thanks
Old Jun 6, 2007 | 02:44 PM
yaoming315's Avatar
Default Re: Rubber washer required when installing Skunk2 shifter? (yaoming315)
n e body?
Old Jun 6, 2007 | 06:36 PM
Byaaah!'s Avatar
Jet Life Til' The Next Life
I would say no, but it's there for a reason...
Old Jun 6, 2007 | 09:13 PM
Dartanian's Avatar
I didn't install them with mine. No problems here.
Old Jun 7, 2007 | 05:29 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
After installing those metal inserts on each side of the bearing, if there is any space left between the shifter and the shift rod, as described in that write-up, you'll need something to take up that space. If you don't, you'll end up with NASTY rattle/vibration problems.
I used a combination of metal washers and a lock washer on mine to keep everything pressed together and rattle-free, and it's been that way for nearly 6 years now.
MidnightB16
Mar 27, 2009 12:50 AM
integra racr04
May 8, 2007 09:38 AM
AMG
Nov 1, 2004 01:35 PM
SupaTegRS
Apr 30, 2003 06:07 PM
