Tricking the automatic seatbelt into thinking that the door is closed all the time
This is my first contribution to the forum in about 3 years just finished college with a BS in Chemistry and am hopefully getting a S2000 or TSX hopefully, and ill be around. Well here is the story my teg was in a bit of a whoopsy on the passenger side, it has been fixed bout 3 years ago. Since then the seat belt started opening on turns and what not about a year ago so it pissed me off hard core. I have searched and found that you can take it to the dealer and they will fix it for free however, I think that is just wasting every bodies time on a 190K mile beat up teg.
So here is what you do if you wanna have it locked back all the time and just plug it in when you come and go.
you need to cut 3 wires
Colors -
Green with red stripe the length of the wire
Black with sliver stripes along the circumference of the wire
Red with yellow the length of the wire
Connect the Green to the black and volia no beeping and the car thinks the door is closed as far a the seat belt goes
Here is a view of the belt warning control unit
Here is a view of the wires cut and "jimmy" riged them together
Disclamer: If you try this I hope you know what you are doing! I am in no way liable if you should expletive it all up so if in doubt find some one who has "exp" (lol the gamer within revels him self). It worked for me so hopefully it will work for you! Good luck and i hope this helps
Modified by H22A EG6 at 12:09 PM 6/6/2007
Colors -
DocYahoo
15
Jul 20, 2002 04:29 PM
