Vacuum line problem w/b16
Okay so i came across this picture for setting up my vacuum lines on a b16 in my ef hatch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a1eg6 »</TD></TR><TR><TD CLASS="quote">
Now on the top middle for the map sensor it shows one side of the hose plugged off.
and the other side running to the throttle body. But it doesn't show the other hose that comes from the map sensor(my map sensor has two vacuum lines coming from it and the above picture only shows one).
Anyone got any insight?
my car starts sometimes and sometimes it won't. it idles crappy when started. i havn't drove it yet though. i followed the picture above except for the map sensor part.
</TD></TR></TABLE>Now on the top middle for the map sensor it shows one side of the hose plugged off.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicflow »</TD></TR><TR><TD CLASS="quote">
the MAP sensor only has one vacuum line port, on the bottom
all the vacuum lines should be fine now but my car won't start.
i had it running for about 5 min after i switched the vacuum lines around. then shut it off. i tried to restart it and now it won't start. it ran roughly and idled at about 2000 rpms.
i pulled the spark plugs and cleaned them off cuz they were black. put them back in and it still won't start.
I converted to obd1 w/a chipped ecu running a p30 map with o2 sensor delete.
I bought a new dizzy from distributor king for obd1 as well.
anyone got any ideas?
Thanks for the replies.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChickenH »</TD></TR><TR><TD CLASS="quote">Main relay possibly.</TD></TR></TABLE>
I switched it out and still the same crap.
anyone know how to id obd0 and obd1 injectors?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxpwr1 »</TD></TR><TR><TD CLASS="quote">were they new spark plugs....your engine could be out of timing</TD></TR></TABLE>
new spark plugs and timing is good
Anyone know how to ID obd0 and obd1 injectors?
well, the car starts but won't restart after it has been running. wtf. i drove it and it pulled pretty good.
it seems it starts on the first try of the day then won't restart for a few hours
93civiccxhatch
Nov 6, 2004 06:37 PM
Reelizmpro
Oct 9, 2004 06:46 PM
