h23 crank in h22
Old Jun 5, 2007 | 08:45 PM
RGSH22ACCORD's Avatar
Default h23 crank in h22
is it possible to do what r the benifits of doing this or should i just stick with my h22 crank
Old Jun 6, 2007 | 12:32 AM
94Vtecluder's Avatar
Default Re: h23 crank in h22 (pinecone)
Increase compression and displacement right? I have never heard of it, and your r/s ratio would be really bad so you wouldn't be able to "reliabley" rev that high to use the power.
Old Jun 6, 2007 | 01:02 AM
AznBlueBoy's Avatar
Default Re: h23 crank in h22 (94Vtecluder)
its been done
made a lot of power
theres a thread about it with dynos
search for it.
Old Jun 6, 2007 | 03:37 AM
hu's Avatar
hu
Default Re: h23 crank in h22 (RGSH22ACCORD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RGSH22ACCORD &raquo;</TD></TR><TR><TD CLASS="quote">is it possible to do what r the benifits of doing this or should i just stick with my h22 crank</TD></TR></TABLE>
It is no problem at all. That is what Birdman did. With the H23 crank, you can use Pauter (H23 rods) and get custom pistons or you can use a H22 off the shelf rod and still have to get custom pistons.
To get horsepower you need to rev the engine. To get torque you have to stroke it. H23vtec is the way to go with the heavy BB.
Make sure the crank is balanced. Castillos in CA does the best work.
Old Jun 6, 2007 | 06:46 AM
NirVTEC's Avatar
Default Re: h23 crank in h22 (hu)
Awesome torque curves!
Old Jun 6, 2007 | 07:30 AM
preludefien
Guest
Posts: n/a
Default Re: h23 crank in h22 (:=:NirVTEC:=:)
im doing the same right now. the h23 crank gives you a longer stroke making more power. you will have to use h23 rods and h22 pistons which in turn will be the h23 vtec. the h22 head as well. with the h23 crank you will have to bend the oil spitters or get rid of em. i just bent mine. not a big deal though.
Old Jun 6, 2007 | 08:48 AM
road.head's Avatar
Default Re: h23 crank in h22 (preludefien)
sounds like something out of a dr. Seuss book
Old Jun 6, 2007 | 08:50 AM
Default Re: h23 crank in h22 (road.head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludefien &raquo;</TD></TR><TR><TD CLASS="quote">im doing the same right now. the h23 crank gives you a longer stroke making more power. you will have to use h23 rods and h22 pistons which in turn will be the h23 vtec. the h22 head as well. with the h23 crank you will have to bend the oil spitters or get rid of em. i just bent mine. not a big deal though.</TD></TR></TABLE>
Can you tell me more about this setup? How high you rev? Dyno numbers or anything?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AznBlueBoy &raquo;</TD></TR><TR><TD CLASS="quote">its been done
made a lot of power
search for it.</TD></TR></TABLE>
Do you remember the title or key words by any chance?
Old Jun 6, 2007 | 08:58 AM
pray2dalude's Avatar
i thought the h23 crank is a h22 crank stroked.
Old Jun 6, 2007 | 09:42 AM
NirVTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94Vtecluder &raquo;</TD></TR><TR><TD CLASS="quote">
Do you remember the title or key words by any chance?</TD></TR></TABLE>
Heres an H23 VTEC(Accord motor) Stock guts at 10:1cr
SR Intake
Greddy Header
2.5" exhaust
tuned on VAFC2+p28
Similarly modded h22s make ~175/145 on this Dyno
Old Jun 6, 2007 | 09:49 AM
BlacktraxGirl's Avatar
please please please do a search on this and find out all the details of doing this swap. its not as straight forward as it seems.
1 for instance is you can NOT put an h23 crank into a 98+ h22...unless its the SiR crank from japan.
Old Jun 6, 2007 | 09:54 AM
NirVTEC's Avatar
Default Re: h23 crank in h22 (BlacktraxGirl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlacktraxGirl &raquo;</TD></TR><TR><TD CLASS="quote">please please please do a search on this and find out all the details of doing this swap. its not as straight forward as it seems.
1 for instance is you can NOT put an h23 crank into a 98+ h22...unless its the SiR crank from japan. </TD></TR></TABLE>
Ditto that!---I always assume people know that!
Nat, doesn't Jai have an H23A VTEC in his 5th gen???
Old Jun 6, 2007 | 11:28 AM
AznBlueBoy's Avatar
doesnt fit 98+ because of the bigger mains right?
Jai has a factory H23A VTEC that came from an accord wagon or something?
those are rare though.
Old Jun 6, 2007 | 11:43 AM
NirVTEC's Avatar
Default Re: h23 crank in h22 (AznBlueBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AznBlueBoy &raquo;</TD></TR><TR><TD CLASS="quote">doesnt fit 98+ because of the bigger mains right?
those are rare though.</TD></TR></TABLE>
Yes, 98+=Bigger Mains but as Nat could tell(IIRC) you, the early 98's came with the 50mm H22A4 from the 97's.
The H23A isn't that rare.....they can be found and aren't that expensive. Theres another thread going right now....~$1500/longblock-no trans
Yes, Accord SiR Wagon and AUTO TRANS only....thats why you will see people selling Engine only. The guy I know just used a US H22 Trans with his...
I always suggest to play it safe and just source A1 parts.....i.e. H23A1 crank in H22A1 block. The H23A1 works in the JDM motors as well, but its easy to confuse them.
H23A VTEC
I have never done business with them though........My EG Hatch is screaming for one as we speak!
Old Jun 6, 2007 | 12:20 PM
P13_mein's Avatar
cheap stroker, only works for the pre-97 H series blocks.
power sooner/ revs less
piece of crap when done sloppily
NOICE engine when done properly
Old Jun 6, 2007 | 12:52 PM
NirVTEC's Avatar
Default Re: h23 crank in h22 (P13_mein)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P13_mein &raquo;</TD></TR><TR><TD CLASS="quote">cheap stroker, only works for the pre-97 H series blocks.
Yah with the Post 97 block you can use the F23
Is NOICE like NOYCE as in Nice or an incorrectly spelled NOISE?! Hahahaha!
Old Jun 6, 2007 | 01:45 PM
road.head's Avatar
never heard of h23 vtec.....innovation i tell you!!
Old Jun 6, 2007 | 02:57 PM
AznBlueBoy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by road.head &raquo;</TD></TR><TR><TD CLASS="quote">never heard of h23 vtec.....innovation i tell you!!
you should start reading the FAQ instead of replying here with your useless posts.
Old Jun 6, 2007 | 03:05 PM
road.head's Avatar
this whole thread is useless budddy.
Old Jun 6, 2007 | 05:44 PM
Rosko's Avatar
lol, why does everyone think you can't rev an H23 crank as high as an H22?
Old Jun 6, 2007 | 05:45 PM
road.head's Avatar
Default Re: h23 crank in h22 (Rosko)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rosko &raquo;</TD></TR><TR><TD CLASS="quote">lol, why does everyone think you can't rev an H23 crank as high as an H22? </TD></TR></TABLE>
because r/s is so important
Old Jun 6, 2007 | 05:54 PM
Rosko's Avatar
yeah I forget how massive these h23 cranks are
Old Jun 6, 2007 | 05:56 PM
Altilude's Avatar
I'm in the same boat, Recently picked up a second jdm h22a block for a build... was just gonna throw some type s pistons in with some a4 rods, but I've been thinking about the h23 crank. is there a way to use the type s pistons with the h23 crank, with some aftermarket rods? or do you have to get custom pistons in the end, to accomodate that crank? I don't want to sleeve or anything so i'd prefer to stay type s with the frm.
Old Jun 6, 2007 | 05:58 PM
road.head's Avatar
Default Re: h23 crank in h22 (Altilude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Altilude &raquo;</TD></TR><TR><TD CLASS="quote">I'm in the same boat, Recently picked up a second jdm h22a block for a build... was just gonna throw some type s pistons in with some a4 rods, but I've been thinking about the h23 crank. is there a way to use the type s pistons with the h23 crank, with some aftermarket rods? or do you have to get custom pistons in the end, to accomodate that crank? I don't want to sleeve or anything so i'd prefer to stay type s with the frm.
your thinking too hard.
Old Jun 6, 2007 | 06:00 PM
Rosko's Avatar
just use H23 rods with that combo, but keep in mind the compression will be up there so you might want to tone it down a bit with a thicker head gasket. also if you run a high lift camshaft be sure to clay the motor at assembly, otherwise thats a great combo.
OR you should just buy all of 98vtec's stuff... H23 crank, crower rods, 89mm wisecos pistons, thicker cometic head gasket hell of a deal!
