b16 head on gsr block
i need to know what oem head gasket and timming belt i need to run on a jdm b16 head and obd2 gsr bottom end...and also what would be the compression when i use a oem head gasket?
thanx
thanx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tmanrose2007 »</TD></TR><TR><TD CLASS="quote">not to disappoint you but one of my friends has this combo and this combo (for him) doesn't work</TD></TR></TABLE>
he did something wrong cause i know this combo works...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delsoldrew »</TD></TR><TR><TD CLASS="quote">i need to know what oem head gasket and timming belt i need to run on a jdm b16 head and obd2 gsr bottom end...and also what would be the compression when i use a oem head gasket? thanx</TD></TR></TABLE>
b16 and gsr headgaskets are the same. use a gsr/itr timing belt. check compression ratio at http://www.zealautowerks.com
your friend is a moron
[QUOTE=doood]b16 and gsr headgaskets are the same. use a gsr/itr timing belt. check compression ratio at http://www.zealautowerks.com
thanx!!!! thats the best thing i have ever seen!!!
I use gsr head gasket, head studs (golden eagle) and gsr timing belt for mine.
Usually you stick with the block on frankensteins.
Compression would be around 10.2:1 if block is USDM.
