ITR front sway on a 97 EX civic (EK)?
Old Jun 5, 2007 | 05:58 PM
BLCK97EKCOUPE's Avatar
Default ITR front sway on a 97 EX civic (EK)?
I'm thinking for grabbing the front sway locally from a HT member (already got his rear sway). Will it fit on my EK? http://www.hondamarketplace.co...97701
If it'll fit, what about the stock endlinks, will it fit? Do I have to get something else?
Old Jun 6, 2007 | 01:24 AM
BlueIntegraBoy's Avatar
Default Re: ITR front sway on a 97 EX civic (EK)? (BLCK97EKCOUPE)
It will fit, but you will need the ITR/GSR endlinks
Old Jun 6, 2007 | 05:55 AM
6SPD_EK's Avatar
Default Re: ITR front sway on a 97 EX civic (BlueIntegraBoy)
no it won't fit!!!!! ITR front sway will fir 92-95 eg's but NOT EK's - in order to fit I think you need eg/dc LCA's & crossmember if I recall correctly
Old Jun 6, 2007 | 02:03 PM
Default Re: ITR front sway on a 97 EX civic (6SPD_EK)
ok, I'm getting conflicting info. Anyone else want to chim in to confirm one or the other before I get it? If I have to swap out the lca and such, I'll just stick with my stock front sway.
Old Jun 6, 2007 | 02:13 PM
slowpokecivic's Avatar
Default Re: ITR front sway on a 97 EX civic (BLCK97EKCOUPE)
all you need are the forks and flcas from an integra and you use itr endlinks
Old Jun 6, 2007 | 02:14 PM
cxSHOE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 6SPD_EK &raquo;</TD></TR><TR><TD CLASS="quote">no it won't fit!!!!! ITR front sway will fir 92-95 eg's but NOT EK's - in order to fit I think you need eg/dc LCA's & crossmember if I recall correctly </TD></TR></TABLE>
this is true.. just remember for ek's everything is different.
Old Jun 6, 2007 | 02:15 PM
According to the following thread, you can put a 21mm EG front sway on an EK.
http://www.jdmuniverse.com/for...47935
Old Jun 7, 2007 | 07:42 PM
Thanks BlueIntegraBoy. The link that you provided is great. Looks like I can get the ITR sway afterall. Just need the SI or ITR endlinks and I'll be fine.
n1ghthawk
Nov 23, 2006 11:11 AM
alwaysoverkill
Suspension & Brakes
Feb 12, 2006 08:14 PM
ohitstutu
Jan 30, 2006 06:36 PM
Wazup
May 11, 2003 11:46 AM
