Need help with alternator belt for b16
did a search...No love
1st gen b16 -
Hasports site says 91 integra (my bad for not triple checking), I bought a 94 del sol one that looks to be the same length as the one that came on the motor. The belt I have is Part number 31110-p30-004. Can I use it and adjust the alternator bracket?, or is it worth taking back and getting the integra one?
Thanks for any help,
Monty
1st gen b16 -
Monty
you'll know for sure once you try putting it on. if its too long, then the alt pulley will rub on the frame. if clearance it fine, then there should be no prob if its a little longer.
