changing light bulbs
Old Jun 5, 2007 | 04:51 PM
noss88's Avatar
Default changing light bulbs
searched...couldn't figure out how to change the light bulbs for my stock 92 civic head lights
Old Jun 5, 2007 | 05:36 PM
noss88's Avatar
Default Re: changing light bulbs (noss88)
bump...
Old Jun 6, 2007 | 12:17 AM
White95SiHB's Avatar
1. Pull the plug from the headlights
2. Remove the rubber cap covering
3. Look for the paperclip looking thingie, push it towards the bulb base, then move it down. The metal clip should swivel out of the way.
4. Remove the bulb.
When installing a new bulb, be careful not to touch the bulb with your fingers.
Perform the above steps in reverse when installing a new bulb.
Old Jun 6, 2007 | 01:07 AM
BlueIntegraBoy's Avatar
Default Re: changing light bulbs (White95SiHB)
It's a good idea to wipe the bulb with isopropanol (rubbing alcohol) with to make sure all dirt and oil are removed from the bulb surface.
Snowsrfr
Mar 4, 2010 10:17 AM
dgerej2
Lighting
Sep 22, 2009 12:30 PM
nObOdy65
Jul 29, 2006 04:45 PM
Spooled1.6L
Feb 9, 2004 10:52 AM
