Redline at 3500 rpm!!!
Old Jun 5, 2007 | 04:34 PM
macdaddyman58's Avatar
Default Redline at 3500 rpm!!!
My 1988 CRX Si is redlining at 3500 rpm's! I dont know what the problem is. Can anyone help???? please!!
Old Jun 5, 2007 | 06:04 PM
ef-hatchcrap's Avatar
Default Re: Redline at 3500 rpm!!! (macdaddyman58)
Sounds like you are in limp mode
Do you have cel's?
Old Jun 5, 2007 | 06:18 PM
Mr. Giggles's Avatar
Probably throwing crank angle sensor just like i was.. If this is true, that would possibly mean you need a new dizzy, or some wires were mixed up like mine.. Too bad I already purchased a new dizzy
Old Jun 5, 2007 | 07:01 PM
nihad's Avatar
get a replacement distributor.
Old Jun 5, 2007 | 11:18 PM
.Manny.'s Avatar
Touching My Member
Default Re: Redline at 3500 rpm!!! (nihad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nihad &raquo;</TD></TR><TR><TD CLASS="quote">get a replacement distributor. </TD></TR></TABLE>
NO! find the problem before you start throwing parts at it.
you might be right but that's not a good way of troubleshooting ****.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SmrCRX &raquo;</TD></TR><TR><TD CLASS="quote">Probably throwing crank angle sensor just like i was.. If this is true, that would possibly mean you need a new dizzy, or some wires were mixed up like mine.. Too bad I already purchased a new dizzy </TD></TR></TABLE>
see, I'm sure SmrCRX learned his lesson. dig a little deeper beofre you start buying expensive parts
Old Jun 6, 2007 | 03:06 AM
Wraith's Avatar
maybe loose wire/pin at the distributor connector?
Old Jun 6, 2007 | 11:46 PM
nihad's Avatar
Default Re: Redline at 3500 rpm!!! (.Manny.)
He could of got a used dizzy not go buy a 200 dollar one and if not needed sell it but am pretty sure some thing with the dizzy clean the connctions on the cap and rotor. it can cause the car not to runn.
Old Jun 7, 2007 | 04:45 AM
ef dino's Avatar
i just took my obd0 dizzy off if you want it.. did you just suddenly get a code? i used to have a few codes but it would only go into limp mode after like a month. i just unplugged the ecu and plugged it all back in everytime and it would be fine until it recognized my codes again
Old Jun 7, 2007 | 06:02 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Manny. &raquo;</TD></TR><TR><TD CLASS="quote">
see, I'm sure SmrCRX learned his lesson. dig a little deeper beofre you start buying expensive parts </TD></TR></TABLE>
Yes sir
FastAzzDA
10
Oct 25, 2006 01:53 PM
Magic Wheels
Nov 18, 2005 06:45 PM
vxnine
Jul 25, 2005 03:20 PM
Layziebtnh055
15
Apr 14, 2004 04:46 PM
STHPERFORMANCE
Feb 17, 2004 09:53 AM
