Changing bolt pattern on a civic.
Old Jun 5, 2007 | 03:03 PM
channingd's Avatar
Default Changing bolt pattern on a civic.
Hello all,
First time post.
I have recently bought my daughter a 95 civic and today I got her a set of rims. The guy came to the house and said they would fit. He took them off his 01 accord. Well, they don't fit. After doing my homework, an 01 accord has a 4x114 bolt pattern and the civic has the 4x100. Can this be changed? If I can upgrade the rotors and change the bolt patter that would be fine with me.
Thanks for the help,
Channing
Old Jun 5, 2007 | 03:21 PM
r.wright's Avatar
Default Re: Changing bolt pattern on a civic. (channingd)
honestly, i think it will be a hassle to swap the bolt pattern.
u would need to get a Japanese spec integra type-R 4x114 brake conversion
if you purchased the wheels already then just try to sell them again on craigslist and get some 4x100 rims..
use this guide to measure next time if there arent any other options:
i got the link from here:
https://www.rsracing.com/tech-wheel.html
Old Jun 5, 2007 | 05:54 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Changing bolt pattern on a civic. (Opossum Jenkins)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Opossum Jenkins &raquo;</TD></TR><TR><TD CLASS="quote">honestly, i think it will be a hassle to swap the bolt pattern.</TD></TR></TABLE>
Yup. It's just not worth it. You would need to swap out the entire hub, using parts that are expensive and not easy to find.
There are lots of rims out there (both new and used) that will fit her Civic, including those made for almost any Civic or Integra. Just get ones that fit, with the proper bolt pattern.
Old Jun 7, 2007 | 09:15 PM
. o 69 o .'s Avatar
Default Re: Changing bolt pattern on a civic. (nsxtasy)
you can swap to 4x114, (i did) but you will regret it when you go to find replacement parts for it.
buymesomedunks
Aug 21, 2012 03:56 PM
rm328
Jul 20, 2005 07:31 PM
cilvia
Jun 12, 2005 05:46 PM
wagonis
Jan 6, 2005 08:23 AM
blackwidowed_accord
Apr 1, 2004 12:30 AM
