preventative maint. question
Old Jun 5, 2007 | 03:00 PM
90_Si's Avatar
Default preventative maint. question
I am ordering a SOHC ZC to put into an ef, my question is aside from timing belt and water pump are there any other part that might be replaced for good measure? Also, are those two even really necessary?
Old Jun 6, 2007 | 04:16 AM
H22Apowered's Avatar
Default Re: preventative maint. question (90_Si)
Normally when I get a used motor to put in a car I replace the following just to be on the safe side:
timing belt
tensioner
water pump
rear main seal
front crankshaft seal
take the oil pan off inspect bottom end of the motor replace oil pan gasket
im sure not all of these are necessary but i would at least do the first 4
SpecialRequest
10
Apr 14, 2015 02:45 PM
crxdriver89
Mar 13, 2006 01:49 PM
Intercooler
23
Oct 21, 2005 03:36 PM
Fuster_Cluck
Feb 27, 2003 07:26 AM
