valves makin noise?????
ok i have a b16 in my 89 crx and it sounds like the valves are makin alot of noise but we checked them and everything was right could my springs be worn or what
you may need to replace your lost motion assembly..To tell you the truth, I don't know exactly what it does but I had the same symptoms in my car and my mechanic had me replace them and wallah! No more valve chatter
Although there could be other possible reasons why, you just have to inspect further. Retainers in place? Right gap and torque specs?
these b16 are crazy old. the LMA in most of these engines are ****. replace them with itr/gsr. same ****.
or buy h22 ones and use a washer. do a valve adjustment and you should be good.
dont forget to check everything else too.
1990hondaHF
Oct 1, 2002 10:23 AM
