GSR powerd EF.. BOGGING QUESTIONS!!!! help me!
Old Jun 5, 2007 | 02:32 PM
JDM_rolex's Avatar
Default GSR powerd EF.. BOGGING QUESTIONS!!!! help me!
my parts list...
B18C1-
stock head and valves
Skunk2 stage 1 cams
Skunk2 Intake manifold/ and Skunk2 throttle body(68mm*i think*)
AEM Fuel Rail, and B&M or AEM Regulator(cant remember)....**never had a problem like this i ran it in my other ef and ran fine..***
Stock cam gears
stock block
stock header, 2in piping to a stock size muffler.
Crome P28 ECU, Vtec-5800, redline-8500
YS1 tranny
while on the high way if i drop from 5th gear to 3rd my car boggs at VTEC(5800) it sounds like it is back firing i am unsure but at the same time it boggs. also while i floor my car in first gear i still bogg at VTEC..
things i tried....
changed the Fuel Pressure from 38-40PSI without vacume line....with vacume line 46-48PSI.
*** can this be one of my problems?****
or MAYBE....
my muffler is pretty small its about 1.5 inch or what ever the stock muffler size is.. maybe the back pressure is what is causing my car to bogg.
PLEASE HELP ME GUYS!!!!
Modified by JDM_rolex at 11:06 AM 6/7/2007
Old Jun 5, 2007 | 02:38 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: GSR powerd EF.. BOGGING QUESTIONS!!!! help me! (JDM_rolex)
generally fuel pressure in any honda is 45 psi..
stock muffler size i would say is NOT the problem.. unless your cat is clogged or something, if you have one.
Has any attempt been made to tune the ECU? if you are using a stock p72 basemap, the stock crossover is 4875.. so
i would have to say that your tune is more likely the culprit, unless this is something that just recently started occuring..
Old Jun 5, 2007 | 03:41 PM
JDM_rolex's Avatar
Default Re: GSR powerd EF.. BOGGING QUESTIONS!!!! help me! (sanimalp)
45 PSI with vacum or no vacum line?
Old Jun 7, 2007 | 10:06 AM
JDM_rolex's Avatar
anyone?
Old Jun 7, 2007 | 11:50 AM
mar778c's Avatar
Community Builder
Community Influencer
Sounds like you need tuning. fuel pressure should be about 40 psi at idle with vacuum.
Old Jun 7, 2007 | 02:14 PM
ChickenH's Avatar
does that ecu have a knock sensor? if it hears detonation it will retard timing and bogg about right there.
Old Jun 7, 2007 | 03:54 PM
1clnef9's Avatar
Default Re: (ChickenH)
when you rev the car at idle does the fuel pressure stay the same if it does change the fuel filter had the same issue it woukd bog out at 4800 rpms and i had good fuel pressure but no flow try it out
Brandeezy1
12
Jun 23, 2014 10:17 AM
bLuBoOrEx89_RAZORS_
Apr 22, 2008 09:26 AM
crackerjackjokers
Jan 11, 2006 11:36 AM
Electron Si
12
Feb 18, 2004 02:36 PM
racinghb
Aug 29, 2003 01:59 PM
