Head Gasket
I bought my 97 Sh about 2 weeks ago with 179k miles, and a buddy of mine said i should replace the head gasket because he removed the oil cap while the engine was runing and noticed that there was some very light white smoke coming out.
He also said the it shouldnt be blowing (air not smoke) that much and that its causing me to loose compression... and to have my valves adjusted... :/
should i get a cometic gasket and have the valves tweaked?
you don't have anything supportive to get aftermarket... i could see taking out the middle layer of the OEM headgasket for a little bump in compression. prob notice a difference by getting a tune up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96Civic_Coupe »</TD></TR><TR><TD CLASS="quote">yea that includes labor, and no im not leaking anything
that can't be WITH labor, the parts are nearly that much. If a timing belt change is around $750 or so I'd expect a headgasket to be around $1k.
There isn't anythng wrong cometic either, they are just as good as stock.
I'd do a compression and leakdown test before you start replacing things you may not need to.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96Civic_Coupe »</TD></TR><TR><TD CLASS="quote">the price includes labor and the gasket
/thread</TD></TR></TABLE>
$115 for a head gasket change and all the parts? Run away as far as you can from that....he'll probably put everything back together with old pizza boxes.
There's way too much stuff involved to only charge $115. Seriously.
My head gasket is being repalced as we speak due to a leak into cyl #3.......Local honda dealer qouted 250 for head gasket set and 600 for labor. 150 sounds too fishy!!! get a qoute from another shop and you'll see for yourself
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96Civic_Coupe »</TD></TR><TR><TD CLASS="quote">went to the dealer today, got my valved adjusted + new gasket + an oil change for $140
Sorry, but it wasn't a head gasket. You must be confused.
the engine is running alot smoother and idles really quite now.
:D</TD></TR></TABLE>
Odd how that work's huh
Lay off the purple bud dude.
