how bad are my camber results ?
Old Jun 5, 2007 | 12:38 PM
redDAinteg's Avatar
Default how bad are my camber results ?
I just got an alignment about 2days ago and my Toe was set to zero, but I do not have a camber kit so unfortunatly that was left alone.
My camber results came out to
Rear passenger side 3.3 degrees,
Front passenger side 3.3degrees,
Rear driver side 2.2degrees and
Front driver side 2.5 degrees.
How bad are these results ?
Old Jun 5, 2007 | 02:28 PM
teg97's Avatar
Default Re: how bad are my camber results ? (redDAinteg)
bad enough to have tire wear
Old Jun 5, 2007 | 02:50 PM
redDAinteg's Avatar
Default Re: how bad are my camber results ? (teg97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teg97 &raquo;</TD></TR><TR><TD CLASS="quote">bad enough to have tire wear</TD></TR></TABLE>
thanks, but more information would be more appriciated. Just telling me that i will have tire wear is already a given, but how bad are these results ?
Old Jun 5, 2007 | 04:33 PM
alexisthemovie's Avatar
what are you lowered on? is one side of your car higher than the other?
Old Jun 5, 2007 | 10:34 PM
redDAinteg's Avatar
Default Re: (alexisthemovie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alexisthemovie &raquo;</TD></TR><TR><TD CLASS="quote">what are you lowered on? is one side of your car higher than the other?</TD></TR></TABLE>
well im on ground control and koni yellows.
Old Jun 5, 2007 | 10:56 PM
juda7's Avatar
Default Re: (redDAinteg)
I would look into purchasing a camber kit for your car.
Some suggestions:
Skunk2
Or
Ingalls
Old Jun 5, 2007 | 11:04 PM
juda7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redDAinteg &raquo;</TD></TR><TR><TD CLASS="quote">I just got an alignment about 2days ago and my Toe was set to zero, but I do not have a camber kit so unfortunatly that was left alone.
How bad are these results ? </TD></TR></TABLE>
I'm guessing that's -(negative) camber?
For me and tire wear, I would try to get at least a -1.5 to -1.8 in the front and in the back a -1.1 to -1.5.
What works for me not not work for someone else.
It's just a suggestion.
Old Jun 5, 2007 | 11:14 PM
::MYCORD::'s Avatar
Ehhh... don't worry about it. I have almost the same amount of camber and wear really isn't bad at all. I never liked the look of the car when camber was too close to 0 anyways. Even -1 is boring
Old Jun 5, 2007 | 11:26 PM
1.8L_allmotormilitia's Avatar
Default Re: how bad are my camber results ? (::MYCORD::)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ::MYCORD:: &raquo;</TD></TR><TR><TD CLASS="quote"> Even -1 is boring </TD></TR></TABLE>
-2 is fun through corners.
Old Jun 5, 2007 | 11:29 PM
juda7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ::MYCORD:: &raquo;</TD></TR><TR><TD CLASS="quote"> I never liked the look of the car when camber was too close to 0 anyways. Even -1 is boring </TD></TR></TABLE>
I beg to differ
Old Jun 6, 2007 | 03:45 AM
-DC2-'s Avatar
camber kits are overrated and unnecessary
toe is what wears tires, not camber. i have daily driven -2 to -3deg for years... never a single tire chewed up
Old Jun 6, 2007 | 03:52 AM
Lauj87's Avatar
well from what i experienced having some negative camber is good for cornering. it puts more rubber on pavement under harsh cornering.
GRANT!
Sep 19, 2006 08:12 AM
Flava
Suspension & Brakes
26
Jun 9, 2006 08:56 AM
accordredliner
Oct 3, 2005 04:57 AM
rice a roni
Suspension & Brakes
Sep 27, 2005 01:52 PM
stocker2shocker91
Sep 17, 2005 01:39 PM
