H22'd EK-$2,000!!!!!!!!!! PICS!-RUNS!
I have for sale a H22 swapped 98 EK sedan.
Motor has less then 40,000 miles. PERFECT 260PSI compression on all four cylinders.
Chasis has about 140k on it.
Swap info:
-AEM CAI
-H23 Timing belt Conversion with new honda timing belt, along with a new OEM Honda balancer shaft belt
-All new gaskets-headgasket, oil pan gasket, IM gasket, TB gasket, and calve cover gasket
-Re-built M2B4 (JDM LSD prelude tranny) with about 15 miles on it
-New JDM Internal Coil Distributor
-New Clutchmasters Stage 1 Clutch
-New Findanza 11lb. Flywheel
-New Main Seal
-New Water Pump
-HPC Mount Kit (H22 into EK)
-Driveshaft Shop Stage 1 axles
-DCsports header welded to stock EK sedan exhaust piping-no cat
-RyWire converted engine harness
-Rywire OBD1<OBD2A ECU conversion harness
-JDM P13 Manual ECU
-JDM Prelude Shift linkage
-BRAND NEW Duralast battery
The car needs a new ECU (basemapped P28 would be your best bet), and possibly a new intake manifold with the IAB's on it (these were taken off. you may be able to get the ECU programmer to put that in the basemap, i'm not sure). The brakes also need to be bled badly.
The chasis has a few dings, nothing major. Could use some paint.
I'm selling this for so cheap because I am seriously desperate to get it gone.
There is nothing majorly wrong with the car at all.
It runs, and drives.
I'm not budging on the price. I have well over $6k into this setup. You're stealing it from me.
PLEASE call (409) 718-2840 ONLY if you have CASH IN HAND. I need this gone ASAP.
Thanks.
Swap info:
-AEM CAI
-New Main Seal
-New Water Pump
-JDM P13 Manual ECU
Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKHWhat »</TD></TR><TR><TD CLASS="quote">car isnt inspected or tagged.
it could make it but youd either have to get the brakes fixed or try to make it using the e-brake.</TD></TR></TABLE>
not risking my life for a 2k dollar honda... now if it was a ferarri .. maybe
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKHWhat »</TD></TR><TR><TD CLASS="quote">it angers me that i cant sell this car for that price.
$1800?</TD></TR></TABLE>
Cause H-T is full of low ballers.
Good Price. Maybe if i could sell my car i could buy this one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSlow »</TD></TR><TR><TD CLASS="quote">Let me know if you are willing to part out the swap. I am interested in the motor/tranny/ecu.</TD></TR></TABLE>Too bad you live so far. I would give you 2k right now cash if you lived down the street. LMK about the swap.
royalrebel
Dec 24, 2009 03:16 PM
