leak=rust= help!!!
Old Jun 5, 2007 | 12:10 PM
batzcivic's Avatar
Default leak=rust= help!!!
i have a leak in my 95 coupe pass side. now i looked for hours while my friend hosed it down and i cant find where its comin from..now im waiting for a piece of door trim from honda. now my question is...if that doesnt work is there a product i can put on my floor (under the carpet) to prevent the floor from rustin out ?
Old Jun 5, 2007 | 12:15 PM
pdiggitydogg's Avatar
Default Re: leak=rust= help!!! (batzcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by batzcivic &raquo;</TD></TR><TR><TD CLASS="quote">i have a leak in my 95 coupe pass side. now i looked for hours while my friend hosed it down and i cant find where its comin from..now im waiting for a piece of door trim from honda. now my question is...if that doesnt work is there a product i can put on my floor (under the carpet) to prevent the floor from rustin out ?</TD></TR></TABLE>
When?
Check out http://www.rustbullet.com/Prod...aTech
(its one of the H-T advertisers)
Old Jun 5, 2007 | 12:20 PM
batzcivic's Avatar
Default Re: leak=rust= help!!! (pdiggitydogg)
what you want a time line? ok
12:00 got the hose out and started weting the car
2:00 stopped couldnt find anything
3:00 went to honda and order a piece of trim
4:00 went on honda tech
Old Jun 5, 2007 | 12:50 PM
NOFX's Avatar
H-T White Ops
He was being sarcastic since you said you did all of those "now", that is, this moment, all at the same time.
Apparently there's issues with not being enough seam sealer on Civics though. So that is why sometimes cars get leaks on the front floor.
Old Jun 5, 2007 | 01:16 PM
Leung's Avatar
Default Re: leak=rust= help!!! (NOFX)
Anyone find out exactly where it leaks in the firewall yet? circle it with pics if somone can make it easier for everyone. My 95 has wet carpet exacly where the right passenger foot is.
here a link for 92-95 related problems
http://consumerguideauto.howst...2.htm
Water leak: There may be water leaking into the passenger footwell because of insufficient sealer on the seam at the firewall. Look for rust on the floor pan and run water over the right lower corner of the windshield to watch for water leaks before buying the car. (1992-95)
Old Jun 5, 2007 | 01:35 PM
batzcivic's Avatar
so theres nothing i can do in terms of rust prevention on the floor?
Old Jun 5, 2007 | 01:54 PM
NOFX's Avatar
H-T White Ops
Default Re: leak=rust= help!!! (Leung)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Leung &raquo;</TD></TR><TR><TD CLASS="quote">Anyone find out exactly where it leaks in the firewall yet? circle it with pics if somone can make it easier for everyone. My 95 has wet carpet exacly where the right passenger foot is.
Water leak: There may be water leaking into the passenger footwell because of insufficient sealer on the seam at the firewall. Look for rust on the floor pan and run water over the right lower corner of the windshield to watch for water leaks before buying the car. (1992-95) </TD></TR></TABLE>
Your link is incorrect
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by batzcivic &raquo;</TD></TR><TR><TD CLASS="quote">so theres nothing i can do in terms of rust prevention on the floor?</TD></TR></TABLE>
You could spray it with a rust preventing spray paint I suppose.
Old Jun 5, 2007 | 01:58 PM
Team RS2's Avatar
i rember als there was a tsb for the heater core, becomeing old and water leaking in the intrior passenger foor board ot check the hoses down there
**** if i can still rember my in.honda.net, log ininfo ill print, scan and email you the tsb
turboorsupercharger
Sep 15, 2008 12:54 PM
wuzzsup_09
Nov 13, 2005 07:10 AM
dansaleen_04
Aug 7, 2005 06:38 AM
jackson93
Aug 6, 2005 09:30 AM
Dropped90Integra
Nov 9, 2004 09:49 AM
