is this a integra type r head? need to identify it.........
Old Jun 5, 2007 | 11:17 AM
Ignitecivic's Avatar
Default is this a integra type r head? need to identify it.........
is this a type r head? at first i thought it was a b16a2 head , but when i bought a exhaust manifold gasket for it, it wouldnt fit. when i bought the gsr or type r gasket for it, it fits.
Old Jun 5, 2007 | 11:19 AM
nholmes's Avatar
I'll be nice since you're local...
Have you tried searching?
Old Jun 5, 2007 | 11:33 AM
Default Re: (nholmes)
yeah i search, but everyone say its hard to tell since b16 and type r share the same code. the valves springs been replace so i cant tell from there.
Old Jun 5, 2007 | 11:44 AM
nholmes's Avatar
Default Re: (Ignitecivic)
https://honda-tech.com/zerothread?id=898679
Old Jun 5, 2007 | 11:45 AM
neo_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ignitecivic &raquo;</TD></TR><TR><TD CLASS="quote">yeah i search, but everyone say its hard to tell since b16 and type r share the same code. </TD></TR></TABLE>
So what makes your question any different?
Old Jun 5, 2007 | 12:24 PM
Default Re: (neo_)
i read every posts about pr3. theres no specific post that can identify itr head
Old Jun 5, 2007 | 12:39 PM
tartje's Avatar
apart from the factory port and polish on the ITR head, they're the same
Old Jun 5, 2007 | 01:27 PM
FullRaceHonda's Avatar
Default Re: is this a integra type r head? need to identify it......... (Ignitecivic)
that just looks port and polished, and .....some of the valvetrain is missing?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tartje &raquo;</TD></TR><TR><TD CLASS="quote">apart from the factory port and polish on the ITR head, they're the same</TD></TR></TABLE> and the valves and valve train
Old Jun 5, 2007 | 11:00 PM
tartje's Avatar
Default Re: is this a integra type r head? need to identify it......... (FullRaceHonda)
the valves don't tell him whether the head is from an ITR or not. how does the purchaser know the seller hasn't just put ITR valves in it and is palming off a B16 head?
Old Jun 6, 2007 | 06:10 AM
MatrixShark's Avatar
Try to bolt up either a B16/ITR intake manifold ot a GSR intake manifold. That should answer your question.
Old Jun 6, 2007 | 07:54 AM
sauceja's Avatar
Default Re: (MatrixShark)
PR3 is the B16/Type R code. It was made in 98 so it could have been on either the 98 Type R or the 99 Civic SI. Most likely they are made the year before so my guess it is B16 SI.
Has it been ported? or is it rough in the ports and only the intake side by the valve stem/guide been smoothed out. If so then possible Type R.
Can you see green paint over by the dizzy mount?
If it is a B16 head and has been ported and polished then who cares. The LMA's would be the closest thing to a difference and the combustion chamber.
Old Jun 6, 2007 | 11:49 AM
Default Re: (sauceja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MatrixShark &raquo;</TD></TR><TR><TD CLASS="quote">Try to bolt up either a B16/ITR intake manifold ot a GSR intake manifold. That should answer your question.</TD></TR></TABLE>
the b16 intake manifold fits fine.
i dont see any green paint over by the dizzy , but there is a green paint behind the head
Old Jun 6, 2007 | 10:15 PM
Circuit Star-29's Avatar
PR3-3 or PR3-4 can be R.
P30 should be stamped on the the portion next to the Dizzy mount. The intake ports should be polished.
If this is done, then you're good.
Old Jun 7, 2007 | 09:07 PM
Default Re: (Circuit Star-29)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Circuit Star-29 &raquo;</TD></TR><TR><TD CLASS="quote">PR3-3 or PR3-4 can be R.
If this is done, then you're good. </TD></TR></TABLE>
thanks for the info. i dont see the p30 stamped but i do see 30 stamped
Old Mar 28, 2009 | 10:10 PM
LLANTAS's Avatar
im going to purchase a type r motor but im not sure if it really is a type r or not does it have a certain number im not sure i dont really know all about the motor numbers
Old Mar 29, 2009 | 05:00 AM
Dave-ROR's Avatar
Uhhh why did you reply to a 1.75 year old thread with a new question?
Old Jan 2, 2012 | 09:54 AM
1904wrencher's Avatar
Almost 3 years later. Ppl are still wondering if it a R or not.
It's a security thing.. we need help knowing the true facts and not b.s.
From what I know. Green paint on the dizzy mount
P30 are b16 and type R stamps for the factory just dual valve springs,and yes the intake manifold fits the b16 heads also, the head gaskets are the same.
Hatchieman
Oct 14, 2009 06:11 AM
rac3r
Dec 6, 2004 05:39 PM
trellix78
Oct 27, 2004 10:44 PM
