Clutch and shift linkage
Old Jun 5, 2007 | 09:22 AM
NguyenDC2's Avatar
Default Clutch and shift linkage
Hey, I'm about to change my clutch with a new one. I was wondering if anyone has a link or something that may show me how to do that. I have a mechanic next to me but he is busy working on other cars.
Also, anyone got a link on how to install a shift linkage?
Thanks =]
Old Jun 5, 2007 | 09:26 AM
St Jimmy's Avatar
* B A N N E D *
Default Re: Clutch and shift linkage (NguyenDC2)
Are you kidding?
Your search for clutch install returned 377 results.
Old Jun 5, 2007 | 09:32 AM
St Jimmy's Avatar
* B A N N E D *
Default Re: Clutch and shift linkage (St Jimmy)
https://honda-tech.com/zerothread?id=1977629
Any problem you run into will be covered in those search results because they all say "problem with clutch install" or "help with clutch install" if thats not enough info or if your to lazy to get it yourself then just drive your car off a cliff and you wont need a clutch anymore... problem solved.
Old Jun 5, 2007 | 09:33 AM
NguyenDC2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by St Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1977629
Any problem you run into will be covered in those search results because they all say "problem with clutch install" or "help with clutch install" if thats not enough info or if your to lazy to get it yourself then just drive your car off a cliff and you wont need a clutch anymore... problem solved.</TD></TR></TABLE>
Thanks, can't use search on this computer. Other wise I would.
Old Jun 5, 2007 | 09:56 AM
NguyenDC2's Avatar
Anyone want to help me with the shift linkage link? =]
flytip_21
Aug 27, 2007 04:26 PM
KPGzDA
Mar 25, 2007 10:55 AM
89EF9
Nov 5, 2004 08:45 PM
mtm584
May 19, 2004 01:53 AM
djtony5
Jan 20, 2003 08:33 PM
