Having problems with my short shifter install.
Old Jun 5, 2007 | 06:50 AM
DJLikwid's Avatar
Default Having problems with my short shifter install.
So here's the deal, I bought a Skunk2 short shifter with the energy suspension bushing kit. My buddy from work said he could install it easily, so it took it over to his place and after 5 hours, I left without the spacer put on (my shifter is loose like a mexican *****), the bushing kit wasnt put on, and there are lots of dents/dings/etc on my center console panel from ripping the panel in and out with a screwdriver.
I'm kinda pissed, but I digress. I know my buddy can do it, but we didnt have a whole lot of room under the car and he said he didnt want to take off the bolts for the exhaust cause he didnt know if he'd be able to get em back on (cause theyre rusted).
Anyway, how much should I pay a shop to put on the bushing kit and the spacer? A shop told me it'll cost $45 which sounds reasonable, but I dont know much about cars so I refer to the experts. (the shop is One Six Motorsports in the NW burbs of Chicago if anyone is familiar)
Anyway, thanks in advance.
Old Jun 5, 2007 | 06:57 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: Having problems with my short shifter install. (DJLikwid)
I Highly recommend you do it yourself.
Once you've done it you'll say: "Man, that was easy"
here's a write-up, but it's pretty self explanatory once you're under your car.
http://www.team-integra.net/se...D=631
Basically, find the bushings, unbolt whatever is holding them on, replace/grease, put back on.
The short shifter is easy too, sounds like you left a few spacers out and that's why it's wobbling.
Old Jun 5, 2007 | 07:40 AM
tomithy's Avatar
also, you don't have to unbolt the exhaust, just take it off the rubber hangers and move the pipe out of the way
Old Jun 5, 2007 | 07:43 AM
Ek Forever y0!
Default Re: (tomithy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tomithy &raquo;</TD></TR><TR><TD CLASS="quote">also, you don't have to unbolt the exhaust, just take it off the rubber hangers and move the pipe out of the way</TD></TR></TABLE>
I just worked around mine, Pita, but I got it done.
I don't know about the clearance on your exhaust though, mine was pretty good.
Old Jun 5, 2007 | 07:48 AM
DJLikwid's Avatar
I'm still on the stock exhaust, so whatever the stock clearance is, is what I got.
Old Jun 5, 2007 | 07:52 AM
Ek Forever y0!
Default Re: (DJLikwid)
It might be a little tighter, but I'm not sure.
Go for it, if it's in your way, just unbolt it and sling it out of the way.
DJLikwid's Avatar
My buddy who did it said he couldnt get a good angle on the screw that has the spacers on it, without a full car lift (all we had was jacks), if that makes any sense. He said if he does it again, he'll have to unbolt the exhaust.
Old Jun 5, 2007 | 07:54 AM
DJLikwid's Avatar
If we do unbolt the exhaust, I might pick up some new bolts/screws/whatever in case the current bolts/screws wont go back on if theyre too rusted.
Anyone know what size screws/bolts/etc I need to buy for the exhaust?
Old Jun 5, 2007 | 08:19 AM
tomithy's Avatar
You really don't need to unbolt it. I only used jacks and at the time it was my stock exhaust. I just took it off the rubber hangers and moved it out of the way.
There was enough room to work for me with just a jack and I'm not a little guy.
Old Jun 5, 2007 | 09:53 AM
letsdrive's Avatar
why were you prying at the center console with a screwdriver? it comes off with just a fews screws.
Old Jun 5, 2007 | 10:38 AM
DJLikwid's Avatar
We were taking off the center console (the one around the shifter) without taking off the console right behind it (the one just under the handbrake) and it took hella maneuvering cause of how tight a squeeze it is. Anyway, my buddy was taking it out with a screwdriver and I didnt see the damage to the panel till after.
Old Jun 7, 2007 | 08:25 AM
shawzy93da's Avatar
Default Re: Having problems with my short shifter install. (ek forever guy)
the shifter wont clear the heatsheild plus you have way more room to get the old one out it has to come off ps take the console off dumass
Old Jun 7, 2007 | 09:29 AM
mike-y's Avatar
wow, your buddy kinda sucks haha.
if you took the console over the ebrake off like you are supposed to, you'd see that the rest of it comes out pretty easily.
R1C3Rxs
Oct 24, 2008 07:40 AM
thesamesound
May 23, 2008 09:45 PM
Mike banX
Mar 8, 2005 03:59 PM
Beezle
Nov 23, 2004 09:30 AM
Sergei01
Feb 3, 2004 09:12 PM
