D16Z6 Ignition Timing..
Old Jun 5, 2007 | 04:08 AM
Racing rice's Avatar
New User
Default D16Z6 Ignition Timing..
I think I screwed up my ignition timing when I was changing my distributor somehow. Should I just set my crank to the red 16 degree mark to get me back to the #1 position, then install the distributor the proper way? Any other suggestions would be appreciated. Apparently my battery was bad, that may have been part of my initial issue.
Old Jun 5, 2007 | 04:23 AM
Forty04's Avatar
Default Re: D16Z6 Ignition Timing.. (Racing rice)
If you removed your dizzy you'll have to reset timing with a timing light.
Old Jun 5, 2007 | 04:28 AM
New User
I understand that. However, you have to get the car started first. If you are sparking on the wrong cylinder, the car isn't going to start.
Old Jun 5, 2007 | 04:38 AM
sicones's Avatar
Default Re: (Racing rice)
you just put the dizzy somewhere in the middle, is doesn't matter if the motor is at TDC or not, the dizzy will only go in one way
Old Jun 5, 2007 | 04:46 AM
New User
Default Re: (sicones)
Thanks, I'll give it another try tonight. If anyone else has any more suggestions I'm open to them.
alperx
Engine Management and Tuning
Jun 7, 2011 05:00 AM
95_Civic_4dr
Mar 19, 2011 12:28 AM
bmxer360
Jan 28, 2011 05:50 AM
D16SohcVtec
Dec 3, 2008 07:14 AM
ONE.SIX SI
Nov 27, 2004 04:00 PM
