anyone installed tokico lumina kit
Old Jun 4, 2007 | 07:13 PM
vrrodri's Avatar
Default anyone installed tokico lumina kit
I searched but did not find a thread on this.
I am installing the tokico lumina coilover kit in my ek hatch.
Anyone found the best adjustment to start with? There were no instructions in the box.
Thanks
Old Jun 4, 2007 | 07:17 PM
Eran's Avatar
HT White Ops
What springs are you using?
Old Jun 5, 2007 | 03:08 AM
vrrodri's Avatar
The springs came with the set, UF 502R
Old Jun 5, 2007 | 06:17 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: (vrrodri)
When I had mine I was 5 in the front and 3 in the rear.
Rode on rails son!
I'm assuming it's the 5-way adjustable kit.
Old Jun 5, 2007 | 08:32 AM
mikeycivic's Avatar
Default Re: (ek forever guy)
I have the same issue, I have a set of illuminas I am using with GC sleeves and there is no instructions in the box so I dont know which bushings and bump stops to use or where they go?
Old Jun 5, 2007 | 12:34 PM
vrrodri's Avatar
hmmm, although it came with no instructions, my 5-way adjustable struts came with a bump stop already on the shaft so I assumed that was all it needed.
I am also reusing the same boot cover and top plate. I hope I did it right. Problem though is that I do not know what position to set the adjusters on initally, I have them right around the middle part but it seems that there might be too much slack on the springs
Old Jun 8, 2007 | 01:24 AM
mikeycivic's Avatar
I have the light yellowish bump stop (cut in half) and then 2 black rubber things, do I need all 3 of them?
Old Jun 8, 2007 | 05:26 AM
JKov240's Avatar
Default Re: (mikeycivic)
I just put mine in yesterday and I'm riding 3 in the front and 3 in the rear...but I'm sure I'll play around with it.
You'll need to cut the yellow bump stops.
Old Jun 8, 2007 | 09:59 PM
vrrodri's Avatar
There was a guy riding 5 in the front and three in the back and he said it was very good. I am starting with that setting
Old Jun 8, 2007 | 10:00 PM
Eran's Avatar
HT White Ops
I ride 4 front, 3 rear with H&R Sport shocks. Rides very nice.
anthy08
Sep 10, 2013 12:24 PM
chivasreal
Suspension & Brakes
Sep 9, 2010 09:55 AM
BoltonGSR
Oct 9, 2008 10:47 AM
nb0
Suspension & Brakes
May 22, 2007 06:47 PM
