axle wont go in to the hub
Old Jun 4, 2007 | 05:58 PM
honda_conversion's Avatar
Default axle wont go in to the hub
the axle will not go in to the passanger side hub should i heat up the axle n try 2 slip it in or keep on bangin the hub untill it goes
Old Jun 4, 2007 | 07:49 PM
ITR#132's Avatar
Default Re: axle wont go in to the hub (honda_conversion)
I would find out which part (the axle, or the hub) is bad and replace it.
Old Jun 5, 2007 | 09:32 AM
citrus3000psi's Avatar
Why wont it go in? Basic question...Are the splines lined up?
Can you put the axle in backwords? If that makes sense to try and clean the splines.
Old Jun 5, 2007 | 09:47 AM
chad's Avatar
Moderator
it will go in....you are doing it wrong...
to make sure...pull axel out of tranny and put axel into hub to make sure it will go...without it in the tranny...and do that from the wheel side not the inside
Old Jun 5, 2007 | 10:41 AM
itr1244's Avatar
Default Re: axle wont go in to the hub (chad)
throw the axle in a freezer and heat up your hub.
and pwnd it in
Old Jun 5, 2007 | 03:41 PM
SoCal ITR's Avatar
Default Re: axle wont go in to the hub (itr1244)
line it up + rubber mallet
Old Jun 5, 2007 | 03:52 PM
typeR#0427's Avatar
Default Re: axle wont go in to the hub (SoCal ITR)
did you LUBE up the hub and the splines? It will fit it just takes patience, its a 2 person job if your doing it without a lift, just keep wiggling it untill they are close, then start with the mallet
Old Jun 5, 2007 | 04:04 PM
Tweakmeister's Avatar
Default Re: axle wont go in to the hub (typeR#0427)
I loaded mine up with anti-seize and it slid in...just make sure the splines are lining up.
Old Jun 5, 2007 | 04:12 PM
junkyard racer's Avatar
are you saying it wont go in as in it wont come out?
or you cant get it into the hub as in your re-assembling it?
Old Jun 5, 2007 | 06:49 PM
Default Re: (junkyard racer)
it wont go in the hub im putting the axle back
Old Jun 5, 2007 | 07:51 PM
jaa1311's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">it will go in....you are doing it wrong...
to make sure...pull axel out of tranny and put axel into hub to make sure it will go...without it in the tranny...and do that from the wheel side not the inside</TD></TR></TABLE>
he tells the truth
Old Jun 5, 2007 | 11:17 PM
BoostR41's Avatar
Default Re: axle wont go in to the hub (jaa1311)
did you have to pound the old one out of the hub? if so the splines are probably done. I just had to replace a hub for the same reason
NovaRex
Jan 24, 2016 10:45 PM
honda_conversion
Jun 5, 2007 03:10 AM
GarageAlchemist
Jul 27, 2006 03:04 PM
PIC Performance
Dec 4, 2005 07:12 PM
TypeSH
Jun 28, 2003 03:37 AM
