Starter No Power???
Old Jun 4, 2007 | 04:44 PM
JLefevers's Avatar
Default Starter No Power???
Ok i juss relocated battery to the trunk using a distribution block with 4gage wire running back, starter was working fine then it blew the fuse in the distro block i replaced fuse and checked all other fuses and no power to the starter now. the main harness is getting power but not the starter. took starter and battery to parts house all checked out good. i am stumped the starter power and ground both are good. Is there a starter relay or anything?? any help would be great trying to get this thing running before thursday. MR. Speaker or any other elder any advice?
Old Jun 4, 2007 | 05:19 PM
Mr. Giggles's Avatar
Default Re: Starter No Power??? (JLefevers)
Are you getting spark??
Ps. When i did my relocation my problem consisted of a polarity issue and when i went to ground it, it threw sparks..luckily i didn't fry myself
Old Jun 4, 2007 | 05:39 PM
JLefevers's Avatar
Default Re: Starter No Power??? (SmrCRX)
i cant tell if i am getting spark bc i cant get the motor to turn over at all. any thing else?
Old Jun 4, 2007 | 06:00 PM
JLefevers's Avatar
i know it is not the clutch interlock relay bc it is a 88 crx so anyones else? it was working fine before it blew the fuse in the distrobution block. now with new fuse the starter wont do nothing. but i still have all other lights, horn, radio, cig lighter so..
Old Jun 4, 2007 | 07:31 PM
Crx Jimmy's Avatar
did you try jumping the solenoid with some wire or a screwdriver?
Old Jun 5, 2007 | 05:33 AM
JLefevers's Avatar
Default Re: Starter No Power??? (Crx Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">did you try jumping the solenoid with some wire or a screwdriver?</TD></TR></TABLE>
how would i go about that??? when i took it to the parts store they bench tested it and it was working fine. but when i bolt it up and plug everything up it wont even click or ne thing. i have a snug fit with the female connector and a snug fit with the 12volt power. it is grounded good to the tranny also.
Modified by JLefevers at 10:29 AM 6/5/2007
Old Jun 5, 2007 | 06:30 AM
JLefevers's Avatar
anyone?????
Old Jun 5, 2007 | 07:05 AM
Efbluevtec's Avatar
get a test light and test the female connector if theres power when you try to start it...if no power...then check for fuses...there should be a starter fuse or relay
mdrouillard1983
Jun 6, 2014 05:24 PM
ahem ahem
Aug 23, 2009 06:28 PM
89CivicHb1
11
Oct 26, 2008 06:46 PM
Lude@Heart
10
Jul 27, 2006 04:52 AM
TIRENECK
Jul 14, 2004 09:04 PM
