1991 integra wont rev past 3500,CEL code 16
anyone have any ideas the car is stuck in limp mode and wont rev past 3500 rpms,the only CEL code it is throwing is code 16 injectors,i have tried resetting the ecu and tried another ecu will not come out of limp mode.main relay gone bad?
Modified by skiracer8148 at 3:45 PM 6/5/2007
Might I suggest testing/replacing the fuel injectors? Also, it might be bad/old wiring, sometimes the resistance of the wire trips stuff.....but I'd suggest getting a "new" set of used $20 injectors and testing those out. Your ECU isnt bad, thus replacing it does no good and its in limp mode because somethings out of wack w/ the electrical system....which it so kindly told you what.
i also have that exact same problem right now with my crx. i got the b18a1 and just turbocharged it.. worked fine with FMU until i tried to update the ecu to obd1 and tune it.. now even when i go back to my original setup, i still get the same problem, wont let me go past 3500 rpm and im getting code 16.. i did change the injectors to 440cc instead of the 550cc i had before. i even tried switching the distripbutor to obd1 but that wont even start the car.. i just wanna go back to my original setup until i get everything i need for a pro tune setup..
with that said, i was wondering if you have ever solved the problem you had and what did you do to fix it, any advice besides getting rid of it would be great. thanks
