Removing freeze plugs from an intake manifold
I'm basically doing this with an H22 manifold, but can't find a small enough slide hammer anywhere. What is the next option at removing those plugs?
http://home.comcast.net/~em-engineering/T2T013.pdf (pg 3-4..)
The cyl around the plug is too deep and the plug itself is too deep height wise. I tried hitting it with a small punch at the outter edge and the whole plug just got driven down. Could I use an extractor of some sort?
drill a hole in it, then thread in some kind of screw eye or loop of metal on a machine screw. Then stick a handle of some sort through the eye or loop and pry it out.
vinuneuro
Jun 4, 2007 09:03 PM
BLKCRX
Jan 2, 2003 01:32 AM
