HELP! failed emissions b18b turbo
specs:
b18b turbo
t3/t4
3 " downpipe-straight pipe-magnaflow exhaust
rc 440 injectors
heres what i failed:
cruise limit suppose to be HC(PPM)=170 CO%=1.2
Cruise Emissions: HC(PPM)=342 CO%=7.51
Idle limit suppose to be HC(PPM)=220 CO%=1.2
Idle Emissions HC(PPM)=477 CO%=3.84
anyone have reccommendations? i was told to drive on the freeway for 30 minutes.
thanks
b18b turbo
t3/t4
rc 440 injectors
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 253EK »</TD></TR><TR><TD CLASS="quote">3 " downpipe-straight pipe-magnaflow exhaust
So you're not running a cat, and you're surprised your emissions numbers are high?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral »</TD></TR><TR><TD CLASS="quote">
So you're not running a cat, and you're surprised your emissions numbers are high?</TD></TR></TABLE>
What I do is install my stock cat and burn a quick EPROM with closed loop. That's all it takes for my car to pass. It only takes 10 minutes to install the cat and switch to closed loop then I just switch it back when I get home.
i laughed when i read this title.....
sorry... anyway what are your NOX readings and limits if the NOX is real low you can advance your base timing, run the test with the hood up and make sure they use the big shop fan in front of your car that they are supposed to.
you are failing HC's because you took out the thing that burns off the HC's.. your cat converter and your base timing is most likely retarded as well making it a lot worse.
if your NoX is low your timing needs to be advanced.
i know a little about emissions repair and besides i was in the exact same spot with my DA and this worked perfect.
didnt work for my DC2 though. so its hit or miss
the DA passed with FLYING colors with no cat converter.
but wiggin out that your turbo and fail emissions.... lmao.
instructions: go to ghetto, pay extra, get sticker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABK »</TD></TR><TR><TD CLASS="quote">Well if you advance the timing too much you will cause NOx to increase. Retarded timing won't cause increase in NOx</TD></TR></TABLE>
thought i made that obvious but yeah i didnt state it that way
retarded timing will cause a decrease in NOX and increase in HC and vice versa for advancing.
long story short....... you can manipulate NOX and HC with timing. you can increase and decrease the numbers with the adjustment you make to go either way. and the NOX and HC are altered opposite of each other.
