stage 2 cams?
Old Jun 4, 2007 | 12:40 PM
team 15's Avatar
Default stage 2 cams?
After installing a stage 2 cam, do you have to adjust the valve to get more power or don't touch it? For a 96 gsr.
Old Jun 4, 2007 | 12:55 PM
1turbodc2's Avatar
u should always readjust your valves after installing cams...
what engine management are you using with those cams?? and what other mods do u have to justify that large of a cam??
Old Jun 4, 2007 | 01:02 PM
team 15's Avatar
Default Re: (1turbodc2)
skunk 2 manifold, type r throttle body, rc injector, I/H/E ,complete type r pulleys,
skunk 2 valves, greddy fuel pump and aem engine management.
Old Jun 4, 2007 | 01:08 PM
sauceja's Avatar
Default Re: (team 15)
Type R pulleys huh???
How are you tuning the bigger injectors? Crome, hondata?
Do a valve lash adjustment.
Old Jun 4, 2007 | 01:11 PM
1turbodc2's Avatar
Default Re: (sauceja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sauceja &raquo;</TD></TR><TR><TD CLASS="quote">Type R pulleys huh???
Do a valve lash adjustment.</TD></TR></TABLE>
he says AEM EMS...
but without higher comp pistions you are not taken full advantage of thsoe cams that is for sure..
Old Jun 4, 2007 | 01:39 PM
ABCVTEC's Avatar
Oh no not this guy again. We had like 8 people tell you to not get stage 2 cams until you up your compression and you still did anyway. I guess you don't want to make much power.
I recommend taking your car to a shop and have them do the adjustments.
EDIT: I don't mean to be a *****, but, you came here and asked for peoples opinions and then you didn't even bother to listen.
gustavito1986
May 14, 2008 04:53 PM
wheels01
14
Jun 28, 2005 01:53 PM
514_type R
Apr 20, 2003 02:44 PM
rathead
Mar 4, 2003 07:49 PM
