stage 2 cams?
u should always readjust your valves after installing cams...
what engine management are you using with those cams?? and what other mods do u have to justify that large of a cam??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sauceja »</TD></TR><TR><TD CLASS="quote">Type R pulleys huh???
How are you tuning the bigger injectors? Crome, hondata?
Do a valve lash adjustment.</TD></TR></TABLE>
he says AEM EMS...
but without higher comp pistions you are not taken full advantage of thsoe cams that is for sure..
he says AEM EMS...
Oh no not this guy again. We had like 8 people tell you to not get stage 2 cams until you up your compression and you still did anyway. I guess you don't want to make much power.
I recommend taking your car to a shop and have them do the adjustments.
EDIT: I don't mean to be a *****, but, you came here and asked for peoples opinions and then you didn't even bother to listen.
514_type R
Apr 20, 2003 02:44 PM
