How do you check ATF fluid level?
Hi
I tried to search that topic and I get diff results
some people say engine has to be running
some say it has to be 1 minute after engine is off
So what is the right way to check ATF fluid level in (accord 02)
Thanks
Thanks
Engine Off
a little engine temp is good to get a really accurate reading, but not that much difference between hot engine or cold engine.
The biggest difference between checking it hot or cold will be the size of the blisters on your arm from reaching past the radiator hose. LOL
i ain't sticking my arm down there to check while the engine is running or just hot period. i know if you went to the dealer, they do it while its hot though. they are pretty much set up and know how to do it. otherwise, they'd always have a line out the door if they wait for a car to get cool down for and extended amount of time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.VoRt3X »</TD></TR><TR><TD CLASS="quote">I Heard The Car Had To Be On And In Park While Checking ATF Level. Maybe I Was Misinformed Myself.</TD></TR></TABLE>Most non-Honda cars want you to check the auto-tranny oil with the engine warmed up, idling, in Park. Honda is sorta unusual about that.
Most Hondas want to be checked after they're warmed up & turned off.
You're only supposed to capitalize the first word of a sentence LOL
yeah thats what it said to do on the ford ranger we got, running and in park
AnAccordIsForever
Nov 22, 2005 03:55 AM
