JDM B16A G2 swap into 92 si need help!
Old Jun 4, 2007 | 10:32 AM
hitmancivic's Avatar
Default JDM B16A G2 swap into 92 si need help!
anyone here did the swap before please let me know if there is any wiring need to be changed...
Any modification will need to be done??
thank you for your help..
Old Jun 4, 2007 | 10:33 AM
JKov240's Avatar
Default Re: JDM B16A G2 swap into 92 si need help! (hitmancivic)
Search.
https://honda-tech.com/zerothread/878010
Old Jun 4, 2007 | 11:08 AM
thank you for your help, but the artical includes everything except the B16A gen2...
Old Jun 4, 2007 | 11:50 AM
JKov240's Avatar
Default Re: (hitmancivic)
I wouldn't think that there'd be any differences...is the Gen. 2 an OBD I or II?
Old Jun 4, 2007 | 12:00 PM
mine car is obd1. Both of my jdm engine and ecu are obd1 as well.
do I need to wire up knock sensor or I already got one in my car??? thank you for your patient and help.
Old Jun 4, 2007 | 05:22 PM
JKov240's Avatar
You can get your ECU chipped to not use a knock sensor...otherwise, yeah, you'll have to wire it up.
Old Jun 9, 2007 | 07:13 PM
got the engine in..
2 things need to find out what to do with it.
1. Throttle cable is not the same...which one will work in it(out of what car)??
2. Power sterring hose is not long enough...what to do???
Please help.
xwhitchx
Aug 27, 2009 07:06 PM
Pworld925
Oct 14, 2008 05:58 AM
thisboyjulio
Apr 12, 2008 05:33 PM
92jdmcivicdx
Oct 29, 2004 09:28 AM
q2team
Jan 18, 2004 07:53 AM
