cat question?
Old Jun 4, 2007 | 09:32 AM
kevtec_00's Avatar
Default cat question?
I have a 00 prelude and need to put a cat on it cause it is throwing a catylist code cause i currently have a test pipe in place of the cat.. I have a couple questions. first wanted to know if having it throw that code does the ecu put the car in limp mode because mine is oviously running rich.. Second can i run a high flow cat without it possibly not burn hot enough for the obd II ecu, or should i just go for the obd II cat? Thanks
1sikhatch
Aug 25, 2009 01:12 PM
sporkcrx
Apr 25, 2004 09:30 PM
Anubyss
Aug 2, 2002 09:49 PM
DocV
Dec 21, 2001 06:33 AM
