skunk2 manifold installation...question
I'm using instructions online on installing a skunk2 manifold and i just want to double check to see if this looks correct or not because I'm not supposed to use the brown spacers between the studs/fuel rail.
also want to double check the red circle is that where the air temp sensor goes?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.8L_allmotormilitia »</TD></TR><TR><TD CLASS="quote">cool i stripped one of the bolts on the air temp sensor.....so how can i take it off now? >_<</TD></TR></TABLE>
On your stock mani? Grab it with a pair of vicegrips, they're hella easy to get then.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CleanLikeJdm »</TD></TR><TR><TD CLASS="quote">
On your stock mani? Grab it with a pair of vicegrips, they're hella easy to get then.</TD></TR></TABLE>
cool thanks !
cool thanks !
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by full Circling »</TD></TR><TR><TD CLASS="quote">if that doesn't work, cut a slot in it with a dremel or a hacksaw, and use a big flathead to screw it out. do you have any pb blaster?</TD></TR></TABLE>
it worked.
anyone know about the fuel rail if its put on correct?
it worked.
great news guys i stripped the bolt since that mother ***** didn't want to come out. anyone know how i can take the bolt out where the arrow is? thats the only thing stopping the manifold from coming out of its place.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMorgan »</TD></TR><TR><TD CLASS="quote">looks right. get a better side shot of the mani. if there is no gap between the rail and manifold where it nuts down then it is good to go.</TD></TR></TABLE>
there gap only on 2 of the studs where the fuel rail bolts down, but the fuel injectors are in its place...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Project95LS-VTEC »</TD></TR><TR><TD CLASS="quote">Maybe you should check your headlight fluid...
It seems low...</TD></TR></TABLE>
yeah you should also check your blinker fluid because there might be too much in there and your blinkers are probably blinking faster then they should you stupid ricer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.8L_allmotormilitia »</TD></TR><TR><TD CLASS="quote">great news guys i stripped the bolt since that mother ***** didn't want to come out. anyone know how i can take the bolt out where the arrow is? thats the only thing stopping the manifold from coming out of its place.
Unbolt the bracket from the block if it's stuck on the stock mani,
I don't even have that brace on my manifold anymore, it's fine.
</TD></TR></TABLE>Unbolt the bracket from the block if it's stuck on the stock mani,
wow, you just jumped right into this didn't you? I hope you don't have any CEL's when you finish that generally come with installing skunk 2 IM
. good luck.
. good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Twilightepitaph »</TD></TR><TR><TD CLASS="quote">wow, you just jumped right into this didn't you? I hope you don't have any CEL's when you finish that generally come with installing skunk 2 IM
. good luck.</TD></TR></TABLE>
I finished. No CEL's.
car runs like a champ w/ chipped p28.
. good luck.</TD></TR></TABLE>I finished. No CEL's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Twilightepitaph »</TD></TR><TR><TD CLASS="quote">good job
. I see so many of these threads that say "installed skunk 2 IM and now a CEL". </TD></TR></TABLE>
yeah people get the sensor wires mixed up because 3 of the plugs look the same in the back of the manifold.
. I see so many of these threads that say "installed skunk 2 IM and now a CEL". </TD></TR></TABLE>yeah people get the sensor wires mixed up because 3 of the plugs look the same in the back of the manifold.
mortificationrock
Aug 29, 2007 03:24 PM
E46Kid
34
May 17, 2006 09:57 PM
